gk71f
- Bike owned: gsxr400gk71f
Re: gk71f
hi mike! you should be able to see through the pilot jets,from front to rear, [just]..tiny hole, make sure the main body of the carbs is clear? cheers!!mike151 wrote:Hi, interesting to hear about middle cylinders needing bigger jets, I think someone's cocked up & put the bigger ones in the right hand pair on these.gonna get my main set off again & check them ,cos bikes still not quite right, don't think I cleaned needle jets properly,ie didn't take them out.
Re: gk71f
Was at an autojumlbe a few weeks ago & there were some Gsx 550 carbs which looked exactly the same as mine but had mikuni written on them. I roughly measures them & found them to be the same. Wondering if jets are available for these mikuni carbs & whether they'd work on a gk71
