Radiator Cap Dimensions/X-ref
				SPOONDIDDLY
G'day guys,
I'm looking to do an overhaul on my RVF's cooling system - inspecting, cleaning and replacing everything.
So I have started to stockpile bits for this and the one thing that I am unsure of is the radiator cap!
Does anybody know any aftermarket brand part numbers for radiator caps that will work?
Or the dimensions/specs for what is needed?
I would prefer to go aftermarket than OE as I work in automotive and can easily access parts locally
				SPOONDIDDLY
Re: Radiator Cap Dimensions/X-ref
So nobody has an alternate part number or a spare cap that they could measure up?
If I have the correct measurements I can find a suitable part number and post the x-ref for all
				SPOONDIDDLY
So I take it that no NC30/35 owners have radiator caps?
				richyrd5
Hi.i have a cap to hand.what do you need know chap?
				SPOONDIDDLY
Brilliant!
I guess I need to know:
- diameter of the main seal
- length from the top of the cap to bottom seal
- Inside diameter of the radiator cap (not including the toggles that hold it on)
- Distance between the toggles
- Pressure that the caps rated to (if it's printed on the top)
				richyrd5
As written:38mm
21mm
43mm
33mm
1.1.
Hope that helps..
						21mm
43mm
33mm
1.1.
Hope that helps..
				SPOONDIDDLY
Perfect! Thanks mate!
				richyrd5
				SPOONDIDDLY
Just one more quick question mate - does it have a bayonet fitting or a screw fitting?
				richyrd5
Bayonet..
