NC30 total loss with Ignitech CDI
TyeNoodle
Bike owned: 350LC KTM300 NC30
Post by TyeNoodle »
So was having a bit of a play this afternoon with the NC30, got it running better than it ever has so opted to try some variations that were easily accessible!
I'd read somewhere that going total loss would yield a 1hp gain so ran it with the reg/rec unplugged then ran it with it connected. The results were surprising!
Over 1hp lost with it disconnected! I did a few runs of each to check for consistency, and they all came out near as damn it the same.
Wonder why? Is it because the Ignitech likes a lot of volts?
bikemonkey
Re: NC30 total loss with Ignitech CDI
Post by bikemonkey »
Total loss only really helps when you remove the entire alternator.
Just unplugging the reg/rec won't be in any way helpful as you've found out.
TyeNoodle
Post by TyeNoodle »
Very true, however I'd have thought there would have been a bit of a gain as there is less of a load on the alternator. Not a 1hp loss throughout!
And the question of why is there a loss is bugging me. If the readouts had been the same it'd have made a bit more sense!
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Nice graph Paul - so whats the score with the air fuel mix ? i never understood these. above the line good ?
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
CRM wrote:Nice graph Paul - so whats the score with the air fuel mix ? i never understood these. above the line good ?
Above the line is lean and below is rich.
TyeNoodle
Post by TyeNoodle »
Thanks Paul, I'm quite happy with it barring the low power, but then it was roasting in the dyno room & not much cold air coming from the outside!
Along the dotted line is perfect, above being lean & below being rich. Fi bikes can be made to near enough follow the line, carbs will never manage it!
CRM
Admin NWAA
Admin NWAA
Post by CRM »
So this would seem pretty good then ? (sorry to hijack)
36 bhp bit down on power there matey :)
Paul (noodle) is this with that fancy airbox? Sorry thread drift
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Drunkn Munky wrote:36 bhp bit down on power there matey :)
That's the CRM :whistle:
TyeNoodle
Post by TyeNoodle »
Stock airbox that Tony.
