What did you do with your NC30/35 today?
Cru Jones
Bike owned: NC35
Re: What did you do with your NC30/35 today?
Post by Cru Jones »
Checked the valve clearances, replaced both tires, changed fork oil and replaced the clutch cable. Busy weekend, but should be good for a while now. :)
...2T bikes exist and are ready to meet your 4T challengers. - ToraTora
quaterchicken
Bike owned: 4HM, NC30
Post by quaterchicken »
From my Sunday ride, pissed down with rain shortly after the picture was taken. :grin:
jimmytanko
Post by jimmytanko »
Thought i had a buyer for mine, but was just someone messing me about, so iys new rear tyre today and fresh 12months MOT tomorrow so if/when someone does buy it it can just be used straight away.
Speedy
Bike owned: RVF400RR, ER6n
Post by Speedy »
Sorted out a rusted stud on the manifold and cleaned up the exhaust a bit, and the swingarm, back wheel, cut the front sprocket cover, etc, etc; the list of jobs seems to be growing rather than shrinking.
Next on the list is a refresh of my WP shock, which I must say that even though I've had it for some 8 years, it probably only done under 10k miles, but the spring has quite a lot of rust; now's a good opportunity to get it done though!
The RVF is still a long way from seeing tarmac yet!
Image Image
Image Image
Image Image
jimmytanko
Got a fresh MOT on the old girl, sailed through no advisories well chuffed, just wish i wasnt selling it now but needs must
JC120
Post by JC120 »
Just took mine for a test ride with the new forks and brakes. Still needs some adjusting.
V4ia addict
manicguitarist
Bike owned: RVF400 (NC35)
Post by manicguitarist »
JC120 wrote:Just took mine for a test ride with the new forks and brakes. Still needs some adjusting.
New forks?
JC120
Post by JC120 »
I've had this bike a little over a year.
I found the forks on eBay for $399 shipped. They're off a 2014 Daytona and they're perfect. 8-) I suppose the seller upgraded to the Ohlins since it came with the bottom triple and steering stem.
I bought the HP Brembo calipers from a guy off of the 600RR forum for $500, custom brake lines from Speigler $130, some Ti caliper bolts, 5mm caliper spacers, a Brembo master cylinder and carbon mudguard from a Datona 675R off of eBay $250.
Should be well worth the $1400,, although I have to fix the geometry.
I took it for a for a test spin and it didn't feel right. I also threw on a Penske rear shock and it's sitting very tall on the kickstand. I think the forks need to come up on the yokes which in turn lowers the front end. I know the Penske raises the rear but not that much.
Brakes work great now and the forks feel really good,, It's just a lot harder to turn than it was. The Penske rear shock needs some dialing in, maybe even a new spring or a rebuild. It's too soft but better than the 20 year old stock one that was on there.
V4ia addict
JC120
Post by JC120 »
Here's some close ups,, Forgot to add the Brembo brake reservoir and then I had to change the fitting to the reservoir on the master cylinder, to a straight one (hopefully I'm making sense). Luckily nothing hits the dash when the bars are all the way to the left.
V4ia addict
Cru Jones
Bike owned: NC35
Post by Cru Jones »
I like those forks. They're hard to find here in the States though. Good find.
