NC 35 clutch transmission
RVF Bel
Bike owned: NC35
Post by RVF Bel »
Your help is appreciated in sequence
Bike starts
Engage clutch in neutral (green light)
Put into first bike stalls
Engage clutch hit the starter engine does not start
Adjusted clutch cable still no difference
Checked pin/collet on clutch cable side all works sprayed it and checked if it pulls in and out it does.
Opened clutch/bell housing
Engaged clutch all plates free
Opened clutch and plates soaked in oil and reassembled
Checked and oiled the one way clutch it's free
Reassembled
Start put in gear and stalls
Still doing the same thing.
I have opened the clutch about three times now got fed up and then
I took the a complete clutch basket and plates including diaphragm of another working bike. Put into this bike still doing the same bloody thing.
Any ideas please?
Re: NC 35 clutch transmission
Is it stalling due to the bike not moving? Put it on a stand, or have someone help you tilt it and get the rear wheel off the floor.
If it stalls due to drag - then check the pushrod too.
if it stalls due to the gear selection then the electrickery needs fiddling and I get confused with all that..lol
Sounds like a dodgy side stand switch to me
RVF Bel
Bike owned: NC35
Post by RVF Bel »
I love you so much thank you! I cleaned the connections and plugged it in and works and treat thank you just need to sort the drag out now. I will adjust the cable accordingly tomorrow thank you.
Very much appreciated.
richyrd5
Regular Member
Post by richyrd5 »
Drunkn Munky wrote:Sounds like a dodgy side stand switch to me
:plus:
