Starting problems and petcock leaking cb400 SF project big 1
dobbslc
Re: Starting problems and petcock leaking cb400 SF project b
Good progress! But I would say that cutting out when you shut off the choke means you still have blocked fuel or air ways in the carbs
These are tiny and carb cleaner won't shift the shit out if that green muck has been allowed to dry in there.
Compressed air and ultrasonic cleaning may be the only way to go.
Just had a thought, have you checked the idle adjustment screw?
mykel49
- Bike owned: CB400SF&BMW G650 X Country
Ok so where is the idle adjustment screw ?
Superjack44
Its underneath the carbs , it is a plastic knurled nut accessed from the lefthand side of the bike as you sit on it, bit fiddly and you can get a bit of a burn if the engine is hot.mykel49 wrote:Ok so where is the idle adjustment screw ?
Having a small hand is a bonus.
mykel49
Hi Dobbsic thanks for that
However, I'm not a 100% sure it is still blocked jets etc.. it's like when I turned choke down to halfway the engine was idling so low it should have stopped anyway, if that makes sense!! so maybe it is the idle adjustment screw, I will adjust that today. Thanks also to Superjack for advice on positioning, and all your advice so far, it's much appreciated.dobbslc wrote:Good progress! But I would say that cutting out when you shut off the choke means you still have blocked fuel or air ways in the carbs
mykel49
Re above - Do you think with my jammed float in carb this is the reason I had fuel getting through to engine oil (smell of fuel from oil ) ?dobbslc wrote: If there is fuel in the oil that means both the tap and at least one carb is letting fuel through.
dobbslc
Defiantly.mykel49 wrote:Re above - Do you think with my jammed float in carb this is the reason I had fuel getting through to engine oil (smell of fuel from oil ) ?dobbslc wrote: If there is fuel in the oil that means both the tap and at least one carb is letting fuel through.
mykel49
Hi there again, well thanks for the heads up, I adjusted the idle screw adjuster when engine running, and hey presto the engine is running sweet and no longer cutting out. this is a brilliant site for advice and guidance.
I also stripped front shocks and replaced corroded dust rings and cleaned up the pitted shocks. I know, I know....I should have replaced the seals and oil whilst I had them off, but seals weren't leaking so just left them for the time being..
untonyto
- Bike owned: 1992 CB400 NC31
Re: Starting problems and petcock leaking cb400 SF project big 1
Followed this thread keenly as I am having a similar predicament on my hands. Thanks to the OP for being an absolute hands-on warrior and to all contributors for guiding him through in detail
