NC30 forks 'VS' NC35
hunter
Re: NC30 forks 'VS' NC35
skinnydog0_0 wrote:I'm testing my bike saturday with Maxton race 675 forks and ohlins TTX rear shock so will report back on how it feels.
Pembrey Jeff.
- skinnydog0_0
- Bike owned: Penny Farthing
Yes mate, you going?hunter wrote:skinnydog0_0 wrote:I'm testing my bike saturday with Maxton race 675 forks and ohlins TTX rear shock so will report back on how it feels.
Pembrey Jeff.
hunter
Yes mate doing a bit of spannering.
TastyNC30
Thanks for all the feed back,
It's a 1992 NC30 so it has late model forks.....
Forks to come out this weekend to be rebuilt!
Thanks again
Chris
Thanks again
Chris
Icemaestro
I'm doing this next weekend for seals and rick oliver upgrade - anyone able to advise what size sockets I'll need? I vaguely remember a 17" or something odd I don't have... And what do do about a fork seal driver?
If you don't have a seal driver put the washer back over the seal and slide some plastic tubing over the stanction to tap it into place, or failing that just tap it in with a decent drift.
Icemaestro
Cheers:-) assume it's right enought that can't be moved by hand...what diameter tubing? I have a wide variety of screw drivers, a nail punch but no drift...maybe a rectangular builders pencil tapped from one end would suffice if I don't have the correct diameter tubing? I assume plastic is as to not damage the seal? Cheers :-) how are you with electrical fault finding?;-) I'm siting here studying the Haynes manual wiring without much success :-p
- skinnydog0_0
Pop over have a cuppa. I'll have a yellow RVF with red and white leathers. #175hunter wrote:Yes mate doing a bit of spannering.
My mate Aled will be there wih his R6 testing too.
- skinnydog0_0
I used to use the old seals to drive the new ones into place- doesnt matter to much if you destroy it getting it out after as you have one for each sideIcemaestro wrote:Cheers:-) assume it's right enought that can't be moved by hand...what diameter tubing? I have a wide variety of screw drivers, a nail punch but no drift...maybe a rectangular builders pencil tapped from one end would suffice if I don't have the correct diameter tubing? I assume plastic is as to not damage the seal? Cheers :-) how are you with electrical fault finding?;-) I'm siting here studying the Haynes manual wiring without much success :-p
There are a few good vids on youtube showing fork seal replacement well worth a watch before and.
Can't remember the size tubing you need I long ago got fed up with messing about and bought a seal driver kit, aslong as you keep the washer on top of the seal you shouldn't damage it. Wrap some electrical round the stancion too save any damage when you slip
What's the electrical problem?
