Ram air fuel pump help
benny
Bike owned: NC30 (track), ZX-9R (road)
Post by benny »
Ok so once the race bikes running again I've got a ram air setup to fit. It has a fuel pump, is this totally needed? If it is then am I ok running total loss with he fuel pump or will my LiPo battery die too soon?
DM104 for the road race team.
Re: Ram air fuel pump help
Your need the pump as the carbs/airbox will be pressurised and yes the battery will be fine
benny
Post by benny »
Drunkn Munky wrote:Your need the pump as the carbs/airbox will be pressurised and yes the battery will be fine
So total loss won't be a problem? Good to know.
I found an old link you posted of a TPS that fits the NC30. It doesn't work anymore, can you remember what it was?
I did one to fit NC35 carbs, 30 carbs are slightly different and there was someone on here that did it to NC30 carbs though.
Yakama
Post by Yakama »
This it? DAC did it.
viewtopic.php?f=24&t=40138
benny
Post by benny »
I think the carbs with my ram air are 35 need to check. What sensor is it that fits the 35? Is it pretty easy?
Thats it
Morespeedvicar
Post by Morespeedvicar »
Could you vent the fuel tank to the airbox to equalise the pressure?
You can but that causes other issues, can't remember exactly but I have in my head that it can cause the fuel to keep flowing when the throttle is shut
benny
Post by benny »
Drunkn Munky wrote:Thats it
What's it? Is there a TPS that fits straight into 35 carbs?
