HRC exhaust downpipes?
- benny
I've got a HRC NC30 exhaust in the loft. I remember reading the fron downpipes are a different sheep to allow clearance for something else? Think it was HRC radiators or something? Is this because the radiators are lowered for ram air?
DM104 for the road race team.
				hunter
Re: HRC exhaust downpipes?
I think the difference is the std pipes are bent to miss the fan,
So i dont think you can fit a fan with the HRC pipes.
I know i cannot fit a fan with my micron system.
you can get the nc30 f3 hrc manual from the downloads section.benny wrote:I've got a HRC NC30 exhaust in the loft. I remember reading the fron downpipes are a different sheep to allow clearance for something else? Think it was HRC radiators or something? Is this because the radiators are lowered for ram air?
the f3 spec nc30 doesnt have ram air just an open set of carbs
- benny
Ah yes. I've got the HRC manual in English! I remember someone on here writing that the different front down pipes aren't just a performance increase but to make room for something else, what was it?Neosophist wrote:you can get the nc30 f3 hrc manual from the downloads section.benny wrote:I've got a HRC NC30 exhaust in the loft. I remember reading the fron downpipes are a different sheep to allow clearance for something else? Think it was HRC radiators or something? Is this because the radiators are lowered for ram air?
- Yakama
Tony, Sneaky peak
  love it
Also it appears there was at least two different HRC exhausts see my post in the F3 sticky
- benny
Does the oil cooler make a massive difference? Is it different to the type that uses a modded water pump cover?
That one is the type that uses the modded water pump cover, i couldnt comment on the difference but i guess HRC thought it was a good idea, pointless with stock rads though.
						- benny
What's the difference with the HRC rads?Drunkn Munky wrote:That one is the type that uses the modded water pump cover, i couldnt comment on the difference but i guess HRC thought it was a good idea, pointless with stock rads though.
Shape, size and pipe routing
