NC35 linkage indentification
- benny
So i have a used NC35 and NC30 shock linkages, I want the NC35 linkage and need to identify which it is. I've misplaced one of the linkages but i don't know which, what can i measure on this one to see if it is the NC35 one?
Ben
Ben
DM104 for the road race team.
Re: NC35 linkage indentification
I need to know this as well.i have both linkages and supposedly have the 35 on on the bike.its says MR8 on the '35' one.but no markings on the other one...
Shorter one is RVFrichyrd5 wrote:I need to know this as well.i have both linkages and supposedly have the 35 on on the bike.its says MR8 on the '35' one.but no markings on the other one...
- benny
as i only have one, i cant see which is shorter. How else can i identify it?
Dont think you can, i'll measure one for you when i go out to the workshop
What about the triangle bit tony.thats the bit that has MR8 on it.is that 35 as well.i know the 35 one has a different bush on it.
Thats the only difference with the tri link, 30 has bushes 35 has bearings. You can press out the bushes and replace with bearings if you you want.
I have the 35 tri link on the bike now.but it does sit low which is why i want to know how to identify which is which..
The tri link makes no difference to the height its the pull arm that affects it
Yes know that.just wondered if the MR8 triangle was 35 or 30
