NC30 Woes
watafu
NC30 Woes
Post by watafu » Tue Dec 02, 2014 6:11 pm
Hi all, so past few days have been a bit of a nightmare as far as my nc30 goes, had a tire blow out on the motorway on the way back to my place to fit some replacement parts to get it through its MOT. Needless to say its now stuck in a garage and out of interest had a pre mot done on it. Saying it failed is an understatement T_T so here is the current list of parts that need replacing as far as I know.
Front discs and pads are badly warped/worn so need replacing, had a lowside on a patch of oil in a corner T_T
Rear disc + pads, luckily I have a replacement ready for this
Rear brake - Seal has gone and lost pressure
indicators - one has decided to die
headlights - apparently only one of them is working which I don't doubt for a second is because I stupidly put higher wattage bulbs in without the required modification so looking at a new left handlebar switch
Tank not secure - Need those little rubber parts that secure it in place
seat not secure - news to me as it was fine when I put it in, guessing just a couple of screws
Head Stock bearings - yea...
Now annoyingly I would have sorted all this out myself but just don't have the time at the minute, hence things falling into a bad state of repair. So looking at a very hefty bill unless I can scrape together the parts to get it through, luckily I should only have to pay labour.
So any advice on where to get parts would be great, please
28hodge
Bike owned: nc30 (track) Yam YZ250 (MX)2st
Re: NC30 Woes
Post by 28hodge » Tue Dec 02, 2014 6:33 pm
Got a set of discs available see my thread over in the for sale section
Loudandproud205
Bike owned: VFR400R3 NC30 NSR125R JC20
Re: NC30 Woes
Post by Loudandproud205 » Tue Dec 02, 2014 7:32 pm
Could be worse your rectifier could have killed your wiring loom like it has mine :(
I have a bike that is taxed tested and insured and the urge to ride but until all the new bits get here and I get the loom, battery and rectifier sorted its going now where and thats if the generator isn't dead as a bonus GRRRRRRRRRR.
Good luck with getting yours sorted and getting back on the road.
28hodge
Re: NC30 Woes
Post by 28hodge » Tue Dec 02, 2014 8:28 pm
Got a flywheel and stator available too if you still have issues after sorting the battery and rectifier
