fork springs nc30 L
- Bike owned: NC30 Race GSXR1100 XR600 ER6
fork springs nc30 L
hi
can anyone show me a pic of standard fork springs and the length for nc30 L
cheers
cheers
- RickOliver
Re: fork springs nc30 L
All standard NC30 fork springs are progressive (i.e. the coils are wound closer at one end of the spring than the other) if your bike has the correct, later type cartridge forks with damping adjustment then the stock springs will be 280mm long with 40mm steel preload spacers. If you have the early type, non-cartridge forks the stock springs are 290mm, preload spacers 150mm.
Rick
Rick
thanks but the springs i have are duel rate 280mm long with 60mm spring spacers also they are the later forks with damping. i'm trying to get a photo on but having problems working it out
done photo added
done photo added
That's a progressive spring out of the later forks just like Rick said.
It's possible that someone has fitted a longer spacer to try and stiffen the forks.
as above.
probbly had longer spacers in it to stiffen out the forks.
ok so standard springs are progressive ???? this 1 is duel rate (look at the pic) or are standard springs duel rate and this 1 is standard???? like i said at the start can any 1 show me a pic of a standard spring??
cheers
cheers
- jim157
thank you for the pic thats the help i needed
rick72
rick72
just to make a cople of things clear it seems that later nc30 forks have duel rate springs as standard not progressive like people are saying this pic should make it alot more clear
thanks for the help
thanks for the help
