knocking sensation from front end under hard braking
igoe1975
Post by igoe1975 »
hello, I was getting a knocking sensation from my front end under hard braking and also it felt unsettled ! had the head bearings replaced but its still doing it ?? any ideas ? just had new fork seals also and fresh oil , its a 1989 nc30 . Also to top off my misery now the bike wont start unless you bump it ! when I press the starter button I just get a single click from relay !!! can anyone help ?
Re: knocking sensation from front end under hard braking
Check your mudguard brackets they can give a knocking sensation when worn
royster81
Post by royster81 »
At a guess I'd say wheel bearings and either your battery is dud or your charging system is dud and running your battery low, either way its only going to hurt you more if you don't fix it.
tigerclaw
Post by tigerclaw »
Check if the discs haven't picked up material and they are biting harder and softer as the wheel turns
alexandervf
Bike owned: NC35
Post by alexandervf »
igoe1975 wrote:hello, I was getting a knocking sensation from my front end under hard braking and also it felt unsettled ! had the head bearings replaced but its still doing it ?? any ideas ? just had new fork seals also and fresh oil , its a 1989 nc30 . Also to top off my misery now the bike wont start unless you bump it ! when I press the starter button I just get a single click from relay !!! can anyone help ?
I am also getting this sensation from my front end under hard braking.... more like using a "pneumatic hammer drill" sensation.
Brake pads and rotors are new (Honda Original parts). I must add that changing calipers,pads and m/c has minimized a bit this sensation but...it's still there....
Wheel bearings that royster mentioned is something that did not cross my mind but is there any way i can make sure they are at fault?
Any other ideas what the problem might be?
ChowderV4
Bike owned: 94 Fzr 400 3TJ ZXR400 Racer
Post by ChowderV4 »
headstock bearings? get the front end up in the air and grab both forks and check for forwards and backwards play
royster81
Post by royster81 »
Does the brake lever pulse ? Could it be warped discs ?
tigerclaw
Post by tigerclaw »
Howsit take an angle grinder worth a wire wheel to the disk. Had this problem on a car, used to shake so hard under braking that we thought the marshals would Black flag us. Look for inconsistent smears of brake pad material on the disk
alexandervf
Bike owned: NC35
ChowderV4 wrote:headstock bearings? get the front end up in the air and grab both forks and check for forwards and backwards play
Headstock bearings are two years old and tightened at the specified torque but i will check this also....
royster81 wrote:Does the brake lever pulse ? Could it be warped discs ?
No, brake lever is firm and steady throughout the braking procedure...Front rotors are also two years old and straight...
alexandervf
Bike owned: NC35
tigerclaw wrote:Howsit take an angle grinder worth a wire wheel to the disk. Had this problem on a car, used to shake so hard under braking that we thought the marshals would Black flag us. Look for inconsistent smears of brake pad material on the disk
There is almost a "mirror finish" surface on the discs on both sides due to pads bedding evenly ...
