Replacement leads / Sparkplug problems
der~kire
- Bike owned: nc24
Hi, just noticed a post bellow, with concern to the HT leads. Its true that with with some car ellectrical systems can have problens with silicone leads, as stated by manufacturer, due to the different voltage rate. Taylor spiro pro leads that I have just purchaced are silicone, and this is writen on there website.
I wonder if this will be a problem on my Nc24? This with the standard coils, and I have also purchased, today, 4 NGK Iridium spark plugs to use with the Taylors. :D
Re: Replacement leads / Sparkplug problems
I'd measure the resistance between the old leads and the new leads, if they are somewhat similar I don't see that you'll have a problem.
der~kire
- Bike owned: nc24
:D thanks neo, allways a good'un.
,, did you use hid equipment in the end, does it all ok?
