cbr400rr nc29-carburetor settings
archeo14
Hi,i have cbr400rr nc29 1995 model.
Therefore i get dry fouling on my spark plugs within every week,cause of this my bike wont start n get problems...
Added i need its carburetor settings also cause i think my carbs getting more fuel n going in dry fouling...
Please help me!
Please help me!
- Davez29
- Bike owned: NC29 forever
Re: cbr400rr nc29-carburetor settings
Hi and welcome.
Someone may move this to the CBR section for a better reply, but in the meantime if you can clean your carbs and search out a copy of a Haynes manual this will be a good start. the mixture screws should be 2&1/4 turns. If its an R model, 1994 0nwards, jets will be 106. But if you dont have a standard exhaust set up it may be higher, such as 108s. Also try a new air filter or if its K&N clean it, make sure you have no leaks on your carb rubbers and air filter.
archeo14
Thanks for ur kind reply..
2 1/4 turns means i dont understand it properly unless you show me in image form..
I put new air filter and iriduim ix spark plugs 6days back n now i m not able to start it due to extra fuel getting burn n coating on spark plugs that leads to not starting n so on...
Thats why i want to set my carbs to fine setting with your all helps
Added i have scorpion exhaust current.
archeo14
SOME BODY HELP ME...
gullarm
2 1/4 turns - you wind them in all the way to the stop, then you turn them back 2 times then a 1/4.
Make sure you remove them 1st and check the rubber washer ( or o-ring ) is in good condition ) My settings were all over the place, after setting correctly it ran like a dream.
dunkenb
On the side of the carbs nearest the engine , if you look underneath you see a single brass screw ( one on each carb)
It adjusts the fuel/air ratio . Screw it in less fuel , screw it out more fuel.
From fully screwed in you turn it out 2 1/4 turns. (If you put a K&N filter on you'll need to adjust the mixture slightly.)
Also if you remove the brass screw completely there'll be a spring , a washer and a little rubber "O" ring behind it.
The o ring can perish.
archeo14
What is 106 and 108s....
Yes its R model cbr400rr n year is 1995.
Please do reply...
Thanks..
Please do reply...
Thanks..
archeo14
Thanks for all ur kind n helpfull replys...i made settings u all said so...lets see,this time how many days its lasting...
Thanksz everyone,ill b putting updates! N please be in touch!!!!
- Davez29
106 is the standard main jet size in the carbs and 108 is the next size up, usually put in if you have any aftermarket exhaust parts or a k&n filter.archeo14 wrote:What is 106 and 108s....
Please do reply...
Thanks..
archeo14
Thanks so much...
