Big Bore Kit
Sunnyday
Bike owned: UK NC30 17" Rear.
Big Bore Kit
Post by Sunnyday »
Anybody fitted the 444 kit and with what results its something me n me pal are thinking about i guess the best results would be gained with a free flowing exhaust and a rejet - for the road i might add not the track.
anybody done it ?
JZH
Bike owned: RSCBRRVFVFRST
Re: Big Bore Kit
Post by JZH »
Yes, but I've neither dyno'd it nor have really noticed much of a difference. My personal view is that the handful of extra ccs is not significant enough for a street bike. I did it only because I could. What would make a difference would be a full engine-swap, but that's a bit extreme.
Ciao,
JZH
London, UK/So.Cal., USA
www.vsource.org
Sunnyday
Re: Big Bore Kit
Post by Sunnyday »
I imagine it would have a stronger mid range - what do you mean about an engine swop ?
JZH
Re: Big Bore Kit
Post by JZH »
I was referring to putting a VFR750 engine in an NC30 (I think someone managed that feat at least once). That would be a good 40hp upgrade, but it's not straightforward and probably has loads of compromises. The 900RR engine in the NC23/29 has always intrigued me, though. The last version put out 151hp...
Ciao,
JZH
www.vsource.org
CRM
Admin NWAA
Admin NWAA
Re: Big Bore Kit
Post by CRM »
I just sold a 440 TTS kitted bike.
full system. total loss system making a healthy 72 at the wheel.
plenty more to come but reliability was the name of the game. the torque curve was linear and it really was a grunty bike - perfect for the road.
just need to treat with care, warm up is essential or the knock the tops if the pistons about and slap when cold.
RickOliver
Re: Big Bore Kit
Post by RickOliver »
I`m with Paul on this one - my 444 engine also makes around 70bhp but the point of the exercise with a big bore kit is that it moves the entire dyno curve up the chart by between 5 and 10 bhp which equals much better midrange and tractability.
Warm up carefully and don`t over rev (I`ve reset the rev limiter on mine to 13,750 from the stock 14,500) otherwise the extra reciprocating mass of the bigger pistons will significantly compromise the service life of your crank and rods.
Rick
JZH
Re: Big Bore Kit
Post by JZH »
Maybe I should ride it more, LOL...
Ciao,
JZH
www.vsource.org
Sunnyday
Re: Big Bore Kit
Post by Sunnyday »
Ok sounds like a diet might be the answer.
