How do you check steering head bearings
stu
Post by stu »
Hey,
How do you guys check the head bearings?
I've always lifted the front end up by tilting the bike on its sidestand, then rocked the bars all the way left and right to ensure the movement is smooth (no notches etc). Then I rock the bike forwards and backwards with the front brake locked to check for fore/aft play in the races.
I checked the bike this way before taking it to have it MOTd this afternoon and it has failed on the head bearings. Am I checking them incorrectly? I've got the bike home and checked them again and my method is not identifying any problem in the bearings although at full right there is very slight tension in the throttle cables which generates a squeak. Surely they were not mistaking tension in the cables for bearing wear?!
Any help/advice is greatly appreciated. Cheers!
stu
Re: How do you check steering head bearings
Post by stu »
On the same note, anyone got the bearing numbers to hand? I don't have my Haynes with me at the mo.
Cheers :)
hunter
Post by hunter »
Can't help you with the part numbers,But the best way to check the bearings is to,
Get someone to pull the bike on it's sidestand so that the front wheel is off the floor,
At the same time keeping wheight on the rear end and leaving the handlbars free,
Squat down on one knee in front of bike,Take hold off the bottoms of fork legs gip firmly in spindle area
With the wheel pointing at your chest,Full forks in to your chest,Then push to rads,
Repeat this to and fro motion do not shake,Push and pull,If there is play you will feel it,
If it's bad you will also here it.
stu
Post by stu »
Cheers Hunter. I've tried this and they still seem fine to me! I'll take it back and get them to show me where they think the problem lies. Thanks for your help
hunter
Post by hunter »
Ok so there is no play,
With the wheel still off the ground opperate the handlebars left and right,
Is it smooth or rough it could be pitting in the cups.
Post by Neosophist »
what exactly do you think the problem is?
There can be excessive movement / not enough and / or play.
as mentioned above, is it notchy when turning the bars left / right
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
stu wrote:On the same note, anyone got the bearing numbers to hand? I don't have my Haynes with me at the mo.
Cheers :)
http://www.akhara.com/nc30/nc30parts/index.htm
91016-MR7-003
