FZR 400 GENESIS CDI FAULTY ???
				kawasakiinit
Re: FZR 400 GENESIS CDI FAULTY ???
not used the mercury one pal but i borrowed a set of them cheapy ones with dials off fleabay which were out of sync at ambient pressure so i decided on the carb tune,when i was asking around which one to get some people were a little worried that the rods in the tubes would give false readings if the bushes got worn etc .all i can say is its brill just make sure its upright when using it so as to get as little drag from the bushes as poss but thats just my ocd talking really mate . the rods have enough weight in them to give a steady accurate reading imo.
				willandrip
An inaccurate gauge is worse than no gauge at all .
Did you get it direct from Morgan with the case . I bet: yes.
Just watching NW200 practice; cracking weather and commentary/footage.
				kawasakiinit
				willandrip
Live streaming;
http://www.bbc.com/s...reland/27251748
First link dodgy; try this;
http://www.bbc.com/sport/live/northern-ireland/27251748
				kawasakiinit
				dobbslc
Talking of carb balancing do you guys know the best place to get the adapters?
I've got a set of Davida gauges and they are good but the brass adapters are complete shoite. Very little metal left after the threads been cut on them.
I've broken a couple of the 5 mm ones now really easily, they sent me a spare for free but he didn't half moan about it and that it must be my fault! Put me right off wanting to pay over £5 each for any more. Does someone make nylon ones as I think they will seal a lot better than the loose fitting brass ones?
Also just ordered a 700° thermal gun for less than £11 off fleabay.
Will test it on boiling water before I use it though.
				willandrip
Don't put that gun in water; it will completely fook it
Try the Morgan site;they do both brass and nylon;
http://www.carbtune.co.uk/carbaccs.html
All gauge tubes are about the same inner dia.
Davida; like owt else USED to be good, pity nearly all UK stuff has turned to shite.
I use an air flow meter
				willandrip
Yes; I have seen your posts on it previously Boris.
Was it from you mini days and twin chokes . ?
I looked and saw they were still available new , ( still only about £40) but was concerned on how altering one airscrew will effect other carbs on the bank and thought going continuously backwards and forwards could be frustrating.
Just a personal experience I suppose.
Actually it was touch and go which I choose but the price from Morgan plus the case and free delivery clinched it.
http://www.ebay.co.uk/itm/BEETLE-Tool-a ... 2a3afbb9f8
Also considered liquid manometers but the fluid evaporates usually and gets spilt if accidents occur.Or worse; sucked up the pipes/bubbles.
Will report back on quality and experiences once it arrives.
				kawasakiinit
dobbslc wrote:Talking of carb balancing do you guys know the best place to get the adapters?
how about these mate ?? surely they can be adapted and much cheapness http://www.ebay.co.uk/itm/5-Pcs-5mm-Thr ... 43bbd3e63c
