fuel spraying out of carbs
				willpisme
- Bike owned: NC30, R1, CB250RS, FZR400
My 1wg is running very lumpy and is missing on 2 and 3 occasionally.
Took the airbox off and ran it to find a fine mist of fuel blowing out of all the carb's when giving it throttle.
Is this because the valves arent shutting fully? Just wondering what the solution is likely going to be before i fully strip it down.
				willandrip
Re: fuel spraying out of carbs
They all do that sir !
It is because you have the airbox off.
When were clearances last checked ?
				willpisme
ah thats great to know thanks! I was getting rather worried about it.
The clearances are next on the list to check.
Does the airbox have a drastic effect on the bikes running? I managed to get it sat on, but its unbelievably hard to get the rubbers over the carbs.
				willandrip
There are approx. 25,679 topics/threads on the FZR General and Workshop sections if the archives are included from 2002.
Of those topics ; about 20% relate to owners failing to get the air box ,which is Critical with a capital C, for Mikuni
downdraught carbs to operate correctly thought the rev/throttle opening range, to fit properly.
Drastic is the very word to describe the effects of incorrect fitment.
Buy new rubbers or search for a recent topic by Drunken Monkey where a silicone hose "bodge" is linked.
1WG covers a spectrum of 4 models with 2 possibly 3 different airbox inlet rubbers.
We shall have to presume you own a Genesis; in which case new rubbers are still available.
				willpisme
thank you. Ill do some searching
				dobbslc
If it's missing on 2 & 3 it could be the coil, it supplies those two cylinders.
Does sound like a coil, check the electrical connection to the coils, undo the block connectors one at a time and check they're not corroded. Check the wires aren't chaffed either.
				willpisme
Got the airbox back on finally. Runs spot on above 8k just really boggy below
				willandrip
The hint was there; you never followed up !
Is it a Genesis; or should it have an Exup valve ?
Well I saw what you did there :)willandrip wrote:The hint was there; you never followed up !
I'm betting it's an exup model
