NC29 - Changing Oil - Can I remove just the lower faring?
marty400
Post by marty400 » Wed May 07, 2014 8:13 pm
Hiya all.
1st time I've done this on the 400! :grin:
(I use to do servicing on 1996 CBR600f, including balancing carbs etc.)
Can I remove just the lower side fairings, to get to the sump plug and oil filter?!
The Haynes manual says to remove the mid fairings, then the lowers for some reason. Are there any annoying plastic lugs that I need to look out for, and not snap if I try to just force off the the fairing lowers?
Hope you can advise
Martin
gullarm
Re: NC29 - Changing Oil - Can I remove just the lower faring
Post by gullarm » Wed May 07, 2014 8:43 pm
If you undo the drain plug with out removing the fairings - which I think you can - drain the oil then you can just reach in and wrench the filter off. Its a bit of a tight squeeze but can be done.
Put some old rags under were the filter is, a small amount of oil will drop out.
Then just fit the new oil filter and refit the drain plug and refill.
I cant remember removing any fairings on my bike.
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn » Wed May 07, 2014 9:27 pm
To remove the belly pan you do need to remove the mid section as there's 2 bolts on each side holding the bellypan on which are hidden by the mid section
marty400
Post by marty400 » Wed May 07, 2014 9:47 pm
gullarm wrote:If you undo the drain plug with out removing the fairings - which I think you can - drain the oil then you can just reach in and wrench the filter off. Its a bit of a tight squeeze but can be done.
Thanks for the tip Gullarm,
I may do that in future, when get the knack, and know the stuff will come easily of next time
For my 1st time though, I'll take the fairings off - I can guess I will get oil splattering everywhere!
Martin
marty400
Post by marty400 » Wed May 07, 2014 9:49 pm
cbr400rrn wrote:To remove the belly pan you do need to remove the mid section as there's 2 bolts on each side holding the bellypan on which are hidden by the mid section
Hi CBR400rrn,
I thought that might be the case!
Will look out for
For future reference, is there a work around I can put in, to avoid having to undo the bolts each time?
Martin
Davez29
Bike owned: NC29 forever
Post by Davez29 » Thu May 08, 2014 12:43 am
Thats the problem with sportbikes, a five minute job turns into an hour due to fairing removal. If you have a decent oil wrench you might be able to get away with just removing the mids but I generally remove the lot, mids, vee and lowers as my brute force method with hammer, driver and hands generally require space. It also lets you check the bike over while unclothed.
marty400
Post by marty400 » Thu May 08, 2014 12:40 pm
Hi Durka,
Good point!
I've set aside Saturday, so may look over the bike properly then :P
Martin
gullarm
Post by gullarm » Thu May 08, 2014 8:57 pm
I always leave as much as possible well alone - especially on these older bikes.
The less you have to remove the less that can go wrong, stuck bolts and misaligned fairings does not make a happy biker and having faring's leaving your bike at high speed is no fun either.
If you can get away with it don't remove it.
marty400
Post by marty400 » Fri May 09, 2014 1:19 pm
gullarm wrote:I always leave as much as possible well alone - especially on these older bikes.
That is a good point Gull Arm.
My 1996 CBR600's farings got really brittle and started cracking bit more each time i had to remove them, near the end before I sold her. (This is even taking into account that I got really good at removing them!)
I've started some new posts on this subject! 8)
