carpman
- Bike owned: 1990 nc30
Post
by carpman » Wed Apr 09, 2014 10:03 pm
Need help identifying 2 things 1 is a bolt attached to each side of frame, the 2nd is my model so i can find out what the colour scheme was. Here is a picture of bolt in its location ( i think it may have been for a crash bung )
I dont know if i'm being thick lol its's a 1990 on the H jap import, frame starts with nc30 101 which I thought made it a K but that is 1989 ! I cant see any carb ID no. and engine number nc13e 1404
royster81
Post
by royster81 » Thu Apr 10, 2014 8:20 am
That bolt is the upper mount for the lower fairings, I guy you've one piece sides or non oe bodywork.
There's a really good site called vsource which has a load of 400 brochures and honda details, one of these is bike id.
Ill stick a link up
royster81
Post
by royster81 » Thu Apr 10, 2014 8:25 am
http://www.vsource.org/VFR-RVF_files/Bvfr400r-mi.htm
It would appear the frame number is right for an '89 bike but the motor is closer to a '90 bike. Maybe it's had an engine swop or maybe some '90 engines went into '89 frames.
Post
by Neosophist » Thu Apr 10, 2014 1:30 pm
proabbyla a bitsa.
AS above, that bolt is to hold the lower farings on, are you missign them?
How aout the front forks / rear shock. do you have the brass screw in the middle of the forks at adjust them or only a big silver screw?
Does your rear shock have a remote resevoir bolted to the frame?
what does the sticker on the undertray say?
carpman
Post
by carpman » Thu Apr 10, 2014 8:33 pm
@Neosophist it has early front forks i think just got the big silver screw/adjuster, no remote for shock, it's currently got tiga dress ( i still have all the other kit that came off ) but from memory the old panels were 1 piece, I'm not going to bin the bolts even though I don't need them they can go in for plating with the other stuff.
