fork spring orientation on an nc30 k series
mentalist
Bike owned: NC30, Ducati996,RD350,Hyperstr
Post by mentalist »
Hi, I'm after some info.
Just cleaned and drained my fork internals. the springs were fitted tighter coils down, but in the Hynes manual for the K series it says they should be fitted tighter coils up?? and all the other models are fitted with tighter coils down.
Is this just a mistake in the Hynes manual??
thanks in advance.
Re: fork spring orientation on an nc30 k series
I've never quite got why it matters - though am sure there is a reason.
You'll be needing the docs section (up top) and get the service manual for it..then see what Honda says.
Job jobbed pal!
mentalist
Post by mentalist »
Cheers, but I've already checked and download the manual and it doesn't mention about the k series early forks with preload only.
Anyone know? ?
Cammo
Post by Cammo »
mentalist wrote:Cheers, but I've already checked and download the manual and it doesn't mention about the k series early forks with preload only.
Anyone know? ?
It won't be in the UK manual as the Uk never got K model bikes.
I would just follow the advice in the haynes manual.
williamshatnerspants
Bike owned: '89 NC30
Post by williamshatnerspants »
I have a K model and the original springs came out with the 'tighter' coil at the bottom. My advice would be to throw the original springs in the bin and put a set of Rick Oliver's springs in. Excellent value and they transform the bike.
NGneer
Post by NGneer »
williamshatnerspants wrote:My advice would be to throw the original springs in the bin and put a set of Rick Oliver's springs in. Excellent value and they transform the bike.
:plus:
Post by Neosophist »
Wouldnt be the first time the haynes is wrong, afterall they had to get a grey bike to do the mods on, could have been fitted wrong in Japan.
I have K model forks knocking around somewhere, I believe they had the tighter coils in the bottom too.
If you cant repalce the forks for later type then fit Rick Os springs. I believe you can transfter them to later forks too if you ever upgrade all you will need is a different spacer.
The later forks offer more adjustment and are cartridge desgin.
Depends on how hard your pushing the bike but overhauling the front and rear suspsion on a K makes a lot of difference to the bike.
mentalist
Post by mentalist »
Thanks for the replys, fitted them tight coils down and fresh oil. Will order R.O. springs later. Cheers.
