r6 shock
hunter
Re: r6 shock
Will it fit,
Sure there was a post on here saying it won't.
richyrd5
Re: r6 shock
well waiting to hear back of someone but,apparently late r6 ones fit??
Re: r6 shock
Best to find out if it will or won't and the year of manufacture before you ask.
richyrd5
Re: r6 shock
as above.late ones fit!(unless the thread on here is wrong?)
Re: r6 shock
Well, your asking on an FZR forum about an nc30 ... whatever that is ?
richyrd5
Re: r6 shock
Really?!? Im asking for a YAMAHA shock(r6.)which i also hear is a mod that is done on a fzr 400.the thread im on about is one on this forum that says a late midel r6 shock is a option and will fit.and if u dont know what a nc30 is...well.
Re: r6 shock
The R6 shock with the red spring will fit the FZR400 1WG with the exception of the 3EN1 because it has a top braced swingarm which will foul the shock. The shock has to be modified, the original has a round profile and R6 is square, just scribe around a washer then get a powertool on it. The top mount has to be packed out. The bike will, however sit approx 25mm lower due to to the shock length so it's advisable to change the dogbones. Kayla of Projection Componants makes them and also the packing spacers they're available on her website.
The 3TJ model can use the same shock but it needs an adapter that bolts to the bottom again available on from Projection Componants.
People say the spring rate on these can be to stiff so factor in the cost of a possible change to bring the adjustment to it's opimum or you could just try it with no compression.
If you want to buy one of these I'd suggest you have a look at the red writing in the pink box above - the one that says Forum Rules and put an ad in the Wanted section of the forum. Alternatively you could try a Yamaha Forum that has an R6 area on it. You not sure which part you're asking for, you not sure it will fit and reffering to a thread that we don't know anything about.
You should have bought a Yamaha.
- CRM
Re: r6 shock
Lol new hear arn't you. and i am guessing young too by the txt speak and shit spelling.richyrd5 wrote:Really?!? Im asking for a YAMAHA shock(r6.)which i also hear is a mod that is done on a fzr 400.the thread im on about is one on this forum that says a late midel r6 shock is a option and will fit.and if u dont know what a nc30 is...well.
Also it may be worth reading and digesting (or get someone to read them out loud to you) the forum rules and how we deal with adverts in the non classifed sections - have you not already had posts deleted for this very reason ?
Lamb to the slaughter here Boris - now where is my popcorn
richyrd5
Re: r6 shock
Thanks for the heads up.on the shock evil..i would reply to all the other bumf.but i really cant be bothered.
