nc29 running problems
dan123
Post by dan123 »
hi i have a 92 nc29 and it appears to only be running on 3 cylinders. when starting from cold the bike is gutless until it warms up then seems to ride fine. on a cold start i checked the temps of the downpipes and cylinder 2 was a lot lower than the others. i left the bike to idle for some time and noticed cylinder 1 was at 260°C, cylinder 2 at 80°C, cylinder 3 and 4 both at 180°C when revving the bike cylinder 2 does raise in temp and feels fine to ride. any ideas what could be causing this?
cbr400rrn
Bike owned: NC29 CBR600F
Re: nc29 running problems
Post by cbr400rrn »
Are you using a tiny bit too much choke and flooding it?
dan123
Post by dan123 »
them readings where taken today and i didnt use the choke at all
dunkenb
Regular Member
Post by dunkenb »
Probably blocked pilot jet on that cylinders carb , had the same on mine .also check the O ring on the mixture adjusting screw, it can perish and suck in air. 8-)
dan123
Post by dan123 »
what size are the o rings on the pilot screws?
mattiec321
Bike owned: GSXR1000K7 Monster HondaPX50
Post by mattiec321 »
I second the pilot jet theory and when were your carbs last balanced?
dan123
Post by dan123 »
only just balanced the carbs and it seems to have sorted the issue out. cylinder 1 and 4 downpipe temps are now about 200, cylinders 2 and 3 about 180.
