NC23 Aero won't spark
Celis93
Re: NC23 Aero won't spark
Post by Celis93 » Tue Feb 18, 2014 4:55 pm
Inside the switches.
Something I haven't mentioned yet: when I bought the bike, it didn't run.
When I pulled the spark plugs, they looked brand new.
So I think it just stopped running, and when they could't figure it out they just sold the bike...
Maybe this brings up some ideas on what the problem can be??
jonathan
Post by jonathan » Tue Feb 18, 2014 6:13 pm
I know you previously said you bypassed the clutch switch but have you checked the diode?
Just in case.
Celis93
Post by Celis93 » Tue Feb 18, 2014 10:36 pm
I checked the diode, one way it is closed, the other way it has a resistance of 560 ohms.
Is this a correct value, or should it be close to 0 ohms?
jonathan
Post by jonathan » Wed Feb 19, 2014 4:44 pm
I think so long as it's closed one way and open the other it will be ok but I checked mine (1989 nc23 k)and it reads 890 and has 8.9 written by the contacts.
Celis93
Post by Celis93 » Thu Feb 20, 2014 2:14 pm
I have used a test light on the coils, to make sure the coils get a pulse.
There is a current on the coils, but the voltage drops when I start cranking.
So the CDI isn't giving a pulse to the coils.
Is there any way to check for a pulse from the pulse generator??
Celis93
Post by Celis93 » Mon Mar 17, 2014 4:34 pm
I opened my cdi and found a loose wire.
I think it should be on the open spot next to the yellow wire.
Does anyone know where the blue-white wire should be connected?
Celis93
Post by Celis93 » Tue Mar 18, 2014 2:14 pm
False alarm, the white-blue wire should be disconnected..
It is an CDI-unit from Carmo electronics.
I really don't know what is wrong with the bike..
Celis93
Post by Celis93 » Fri Mar 21, 2014 7:04 pm
IT'S RUNNING!!! :grin:
Apparently the jump cables weren't capable to deliver enough current to create a spark.. :oops:
Thanks everyone for all your help!
dunkenb
Regular Member
Post by dunkenb » Fri Mar 21, 2014 10:08 pm
:grin: ;) :? :o 8-)
Emzed
Bike owned: NC23J/K,750Paso x2,MZ's,BMW C1
Post by Emzed » Fri Mar 21, 2014 10:35 pm
Well who'd have thought it :lol:
At least you know the electrics have had a good sorting ;)
Just enjoy the buzz now :grin:
