cbr 400rr splutters above 6000rpm help
rochie
Post by rochie »
hi all
in need of your help my cbr400rr nc29 is running crap !!!!!!!
as soon as I get to 6000 revs it just splutters
ive balanced carbs properly using vacuum gauges ive put brand new jets in (standard) a kit from NRP CARBS.new plugs
and its the same
can any one help me in urgent need got a track day on Monday !!!!!!!!!
vr46
Bike owned: All sorts
Re: cbr 400rr splutters above 6000rpm help
Post by vr46 »
5500 RPM restriction?
Does it rev and drive above 6k? if not then the problem may be with the speedo wiring.
Skint Novice F400
rochie
Post by rochie »
hi thank you for replying
yes it drives but very very poor it just splutters and it feels like the throttle is rolling on of so to say
rochie
Post by rochie »
please help
vr46
Post by vr46 »
Not sure really...
Maybe it's worth draining / flushing the petrol tank and cleaning the fuel tap filter? There is also a secondary filter on the fuel tap outlet...
Skint Novice F400
Have you got a speedo plugged in?
If not, plug it back in
rochie
Post by rochie »
hi yes all plugged in
rochie
Post by rochie »
hi all got it sorted
the tps was out also removed K&N filter and put original in
also removed the filter before the the pump and replaced it and rebalanced carbs
runs 100% better now hits the redline no probs customer very happy now hope this info can help anyone else
gareth91
Post by gareth91 »
hi, i have a nc23 cbr and around 6000rpm it sputters for a split second then will rev on up. only happens around the 5-6000 mark. What does tps stand for?
leopard_pagan
Post by leopard_pagan »
Throttle position sensor
