Rear Sprocket Carrier
Rascal
Post by Rascal »
Hi Guys me again,
What's the technique to remove the rear sprocket carrier from the hub. Everything has been loosened off soaked in plus gas but the thing won't move. Other than heat is there another way?
Re: Rear Sprocket Carrier
Never had one stuck, if you remove the large circlip from the other side of the hub you can knock the axle out which will in turn pop the sprocket carrier off
Rascal
Post by Rascal »
OK but won't the brake disk be in the way of the circlip?
