K & N air filter advice.
				wullie3xv9
- Bike owned: GK76a GSXR400R & TZR250RS
Hi all.   I've just purchased the appropriate K&N air filter kit (SU-7592) for my GK76a's stock airbox assembley & would like to clarify what size main jets, needle clip position & pilot jets are required if I fit the larger of the two air inlet rubbers supplied. I'm assuming that no jetting / setting changes are required if I fit the smaller, stock sized inlet rubber supplied. (My bike has a Scorpion end can fitted to stock downpipes).
I've removed the carbs to check them over / clean them out, (they've already been treated to a set of Viton O-rings by its previous owner), so would like to know jets & settings before I rebuild & re-fit them. Thanks in advance.
  Thanks in advance.
P.S. I've trawled through all previous posts relating to K&N filters but couldn't find a definitive answer.
  I've just purchased the appropriate K&N air filter kit (SU-7592) for my GK76a's stock airbox assembley & would like to clarify what size main jets, needle clip position & pilot jets are required if I fit the larger of the two air inlet rubbers supplied. I'm assuming that no jetting / setting changes are required if I fit the smaller, stock sized inlet rubber supplied. (My bike has a Scorpion end can fitted to stock downpipes). I've removed the carbs to check them over / clean them out, (they've already been treated to a set of Viton O-rings by its previous owner), so would like to know jets & settings before I rebuild & re-fit them.
 Thanks in advance.
  Thanks in advance.P.S. I've trawled through all previous posts relating to K&N filters but couldn't find a definitive answer.
				rgvsp
Re: K & N air filter advice.
I'd stick with the stock settings and then adjust if necessary.  I have the larger air filter and kit exhaust and went with a larger main, adjusted clip richer and ended right back at the stock carb settings.
				morris147
Get it set up on a dyno if you want it spot on....
				wullie3xv9
Thanks for the replies, guys.   No definitive answer then?
 No definitive answer then?   I've removed the engine from the frame now so that I can give both of them a good clean up / check over & will check the valve clearences on the engine while it's out.
I'm now seriousley considering buying & fitting the less restrictive stainless steel down-pipes from Sandy Bike Spares via Ebay.
So, does anyone on here, with a non SP model GK76a, have a K&N filter with the LARGE inlet rubber fitted & a Scorpion end-can fitted to the above down-pipes?? If so, could they advise me please what size mainjets, needle clip position & pilot jet size to start with. Would 112.5 or 115 mains, needle clip moved from the middle slot to the 2nd from top slot & stock 47.5 pilot jets be a good place to start & then fine tune from there ??
Cheers.
Wullie.
   I've removed the engine from the frame now so that I can give both of them a good clean up / check over & will check the valve clearences on the engine while it's out. I'm now seriousley considering buying & fitting the less restrictive stainless steel down-pipes from Sandy Bike Spares via Ebay.
 Cheers.
Wullie.
				stripes1976
- Bike owned: 6 gk76a's, nc29
ok 117.5 is a good place to start with the main jet on the dyno but always start rich and come down. I have always tried the 120 main as a base then usually drop to 117.5
For every 3 main jet sizes you increase you will need to go up 1 in pilot. If you dont you have a huge flat spot and bad running in the middle and low down.
				wullie3xv9
Thanks for the info above, Mr Stripes. Can you confirm please that this is the jetting/settings to try with a set of free flowing stainless down pipes/headers, an old, round Skorpion end-can & K&N filter with large inlet rubber fitted. TIA.
