Male blade terminals, what size??
- 28hodge
I'm away from my bike and trying to order some bits to allow me to make up a race loom.
My current loom has been butchered a lot over the years and tracing it and get it neat is becoming a pain in the bum, so I am making up a race loom.
I am going to use the existing block connectors but I am going to need some fresh male terminal connectors, but I am unsure which size I need. Anybody know off hand?
Kojaycat.co.uk offer 2.8mm or 6.3mm.
I need fresh connections into the cdi white plug and black plug and also the right hand switch gear.
I could buy fresh connector blocks and snip the original Honda ones off, but I'd rather retain them and put fresh male connectors into the blocks.
Also anyone got any tips to get the male connectors out of the connector blocks.
- 28hodge
Re: Male blade terminals, what size??
Sorted, in case anyone needs any in the future you need the following,
2.8mm females for the rhd switch gear
2.8mm females for the cdi (both plugs)
2.8mm females for the pulse coil generator
6.3mm females for the red plug out of the starter solenoid
