upgraded sidelights?
jetblack
Bike owned: '89 NC30 SEED
Post by jetblack »
I'm looking to improve my sidelights (I always ride with them on to make me more visible) but as we know the stock sidelights on the nc30 are fairly low wattage and an odd size bulb.
So I'm thinking of getting some 501 bulb holders and wiring them in in place of the stock holders and then running 501 bulbs or possibly LEDs ( to reduce the load on the charging system and to run cooler than incandescent bulbs)
Any one else done this?
Any possible issues/suggestions.
It don't matter if i'm fixin' it or ridin' it.
xivlia wrote:sorry about that whole thing jetblack, i just got confused about the whole thing, and i didnt mean any disrespect to you.
V4beermonster
Bike owned: Vfr400,gt750,vfr400/750cc
Re: upgraded sidelights?
Post by V4beermonster »
I've soldered led bulbs direct into the loom, led take hardly any current. Much brighter and easy to do
jetblack
Post by jetblack »
Cool. So LEDs get your vote? Are they Clearly visible in the daylight? I was looking at those cree projector LEDs but as the bulb is at an angle in the headlight it won't be facing forward so I reckon one of those smd tower ones might be a better bet.
The bulb holders are only a few quid so I've ordered them. Should be a very straightforward swap with the stock holders. Quick job with the soldering iron and away we go. I gather polarity needs to be right with leds but I'll just wire the holder in and then turn the led bulb around if its the wrong way round!
bikemonkey
Post by bikemonkey »
I've used angel eyes in my headlights works well.
I recently had to change from LED form to CCFL though as my headlights melted the LED rings.
I got some 85mm ones from these guys: http://www.driven2automotive.com/
You'll have to message them if you want some.
If you do get them, you'll have to take off the plastic casing as it'll melt, and just use the glass CCFL tubes. Also you'll have to find somewhere to mount the invertor, I just zip-tied it to the headlight bracket.
Can get some pictures if you want, but I forgot to take any whilst I was doing it.
Here's the thread I followed for the LED install, it's just the same for CCFL really: viewtopic.php?f=24&t=37895&hilit=angel+eyes
jetblack
Post by jetblack »
To be honest I'm not really a fan of the angel eye look. I want to keep it stock looking but just give myself more choice of bulb, hence the 501 sidelightholders. Smd LED bulbs are cheap enough that I'll give it a try and if its no good I'll go back to an incandescent bulb but just with a larger 5w bulb rather than the poxy OEM bulb. ( only worry then is that the stock wiring/housing can't cope with the higher wattage/heat.)
V4beermonster
here's mine, think they where ice white and cost about £3 from evilbay delivered
V4beermonster
Remember LED's use less power than any normal bulb and last many times longer, I've just replaced all. My gu10 bulbs at home with LED's which give instant light and are more energy efficient than energy saving bulbs! Plenty on eBay look here http://www.ebay.co.uk/itm/HONDA-VFR-400 ... 2ec1e2bece
jetblack
Post by jetblack »
Ace. Yeah those are 501 fitment bulbs. They dont fit in the jap bike bulb holders so once ive fitted the new holders then ill be able to fit these or similar.
mo haggs
Bike owned: bikeless
Post by mo haggs »
V4beermonster wrote:I've soldered led bulbs direct into the loom, led take hardly any current. Much brighter and easy to do
Any pics of how you fitted them
Sunnyday
Bike owned: UK NC30 17" Rear.
Post by Sunnyday »
If you want to be seen put your headlamps on its safer.
