To bring you up to date, here is brief summary of my shocking shock journey so far:
* 3 Nitrons going wrong. topic: viewtopic.php?f=22&t=39722&hilit=nitron
* Borrowed a modified-for-standard-link GSXR 750 shock and it was pretty cool.
* Had to give GSXR shock back and put my pogo stick back on. Crashed.
* Got a CBR1000 shock for free and set about putting in on. No joy.
So the previous picture of the GSXR shock is my latest attempt. I went to the wrecker this morning to look at buckets of GSXR shocks. The GSXR 600s and 750s of that time used the same shock.
Initially, I was after a 2005 shock. I understood this was the one to get. However, I saw some specs the 2005 online and it had it at about 335mm - which is waaay to long - so I had doubts about it. I had also read the 2005 had a 7.3 spring on it which seemed really soft. The later models had a 9.5 on them so I was keen to see if the later models were the same dimension as the 2005.
Nope. I was disappointed to find the later models were much shorter than the 2005 model ... that is, until I measured and confirmed the 335mm of the 2005! It was actually the later models that were the right length for an NC30. The K6/7 shock picture above is 315mm in length, and unlike the K5 (2005) is has hi/low speeds compression damping. The K5 looks a more basic shock. So ... funnily .. the 2005 model does not look the one to get at all.
I had the opportunity to inspect a BMWS1000RR shock also and it seemed a nice unit, but two local shock specialists said they would favour the GSXR Showa over the BMW Sachs unit. It seems also there is a greater pool of knowledge on tuning Showa compared to Sachs.
So here is the CBR (left) unit vs the GSXR unit (right):
And vs the OEM NC30 unit:
The hi/low speed compresison adjustment:
Both the CBR and the GSXR were the same weight at:
and therefore were lighter than the OEM unit at:
The top mounting bolt was put in there by Dog Himself so I had to bring out the big guns to loosen it:
An initial test fit provided the first disappointment. Despite taking measurements with me to the wreckers, I had heard the GSXR shock was a no-mods fit so I didn't double check. Oops:
The GSXR shock is a bit wider! However, the mount may be wider, but the actual width of the bolt sleeve was only about 1mm-1.5mm greater than OEM or the CBR1000 shock:
Initially, I really didn't want to make any frame mods, but 1-1.5mm is no big deal ... so figuring that if the GSXR shock was not great I'd try the BMW .. which needs frame mods, I thought scr*w it, in we go:
... which didn't get anywhere too quickly, so again I pulled out my cheap-as-chicken-sh*t carbide dremel thingies and set into action. *Man* these thing are great for like, $20 or something:
Bits of frame shock mount ... no more "pining for the fjords" ... :
getting there:
.. and done :
Okay ... it goes in and (not shown) my current battery box seems to fit:
The compression adjusters are a little awkward but not too bad:
.. and the rebound adjuster is on the chain side! ... but manageable:
Voila!:
Funny, I had the OEM shock in to keep things up after I took the CBR one out. So, this time to take it out, as usual, I raised the rear end off the ground etc etc. But to get this one *in* I had to raise it *further*!!
I've got a quote for re-springing and re-valving the GSXR shock which was not cheap, so ... I am hoping the way it is with the 9.5 spring on it will do the business. A sag setup will reveal more .. and I'll likely have a few questions here.
I'll do the sag set up at the weekend when I can rope in the support team.
But .. news just in .... all this work was to get the bike ready for the Phillip Island Classic in January - the largest non-MotoGP bike race meeting in Australia. The NC30 is eligible for 'Period 6' (1982-1990) .... but speaking to the organiser today, they are currently NOT accepting entries for sub-500cc Period 6 machines.
Sh*t, f*ck, boll*cks. Sh*t. I just shelled out $400 for my 'national' level race licence so I could compete!
Sh*t, f*ck, boll*cks. F*cking shi*te boll*cks ....
Aaaameeennnn .....
