NC30 Brake Upgrade Advise Required
Mockery
Re: NC30 Brake Upgrade Advise Required
Post by Mockery »
I'm looking at replacing the master cylinder on my NC30 to get something with an integrated reservoir for a sleeker look. (plus my M/C is old and ratty)
I want to maintain the correct hydraulic ratio, so can anyone tell me what the piston size is in the NC30 Master Cylinder?
If you like, you could also tell me what is interchangeable... :)
Not looking to switch calipers or upgrade as I reckon the standard brakes are fine. Plus I just bought funky ASV levers or else I would look at some bullsh*t-expensive Brembo radial...
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
I seem to recall that the standard master cyl is 11 mm?
Are you gonna go for a naked style master cyl? Can't comment on compatibility, but I know that some naked Hondas run different levers to the usual Honda sprtsbike stylee.
'Take it to the Back'
Post by Neosophist »
NC21 brake resevoir is all in one and it shouldn't be too far off. I know theres a few on ebay for pennies.
fastdruid
Regular Member
Post by fastdruid »
86-96 VFR750F? RC24/RC36
Same lever as the VFR400 although I'm not sure about the bore.
Don't have a clear shot of just the M/C but these two show it.
Druid
RVFJE
Post by RVFJE »
Apart from the original Nissin pads which would anybody recommend for track use using the standard calipers?
fastdruid
Regular Member
Post by fastdruid »
RVFJE wrote:Apart from the original Nissin pads which would anybody recommend for track use using the standard calipers?
If occasional track use then still OEM Nissin, never been out braked yet! :D
Dunno about regular track use but I've heard good things about about bendix and they work a treat on my SV.
Druid
RVFJE
Post by RVFJE »
Druid
Thanks for the info.
There are several compounds available from Bendix - do you know which one it might be?
fastdruid
Regular Member
Post by fastdruid »
My SV is fitted with
BENMRR186 BENDIX SUPERSPORT RACE BRAKE PADS
Druid
RVFJE
Post by RVFJE »
They are the pads I was looking at. Might give them a try.
Mockery wrote:I'm looking at replacing the master cylinder on my NC30 to get something with an integrated reservoir for a sleeker look. (plus my M/C is old and ratty)
Brake ID is 14mm
NC21 is the same ID and its integrated. (that one i posted is on ebay shops, item 260296183293 )
