Electrical Question of the Day....
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
So, do you guys thing an AMP connector (like Ducati uses) would be able to handle the current load from the 3 yellow alternator wires, or should I just stick with the stock connection? I'm re-wrapping and sorting my track harness and replacing all the crappy old connectors with water proof AMP connectors.
Cheers.
Morespeedvicar
Re: Electrical Question of the Day....
Post by Morespeedvicar »
Yeah i would think so, but wouldnt it be easier to just make the engine loom go straight to the reg/rec rather than across the bike a couple a times?
Just a thought.
Ian
vfrman
Post by vfrman »
Perhaps...I haven't given it much thought.
lutorm
Bike owned: NC23, NC30
Post by lutorm »
vfrman wrote:So, do you guys thing an AMP connector (like Ducati uses) would be able to handle the current load from the 3 yellow alternator wires, or should I just stick with the stock connection? I'm re-wrapping and sorting my track harness and replacing all the crappy old connectors with water proof AMP connectors.
Cheers.
Connectors are rated for max currents. I haven't measured the charge current, but anything that can handle 25A or more should be plenty. I used Metri-Pack 280, which also are sealed and rated 30A.
And personally, I really like to have a connector. When the time comes and you want to disconnect it for some reason, it's going to be really annoying otherwise.
vfrman
Post by vfrman »
I agree. But I think I am going to run the wiring up the left side of the bike instead of crossing the v and having it join the main harness.
lutorm
Post by lutorm »
vfrman wrote:I agree. But I think I am going to run the wiring up the left side of the bike instead of crossing the v and having it join the main harness.
Oh, yeah. I did that too.
400RRJ
Bike owned: CBR 400 RRJ NC23
Post by 400RRJ »
if your looking at replacing connectors for a race harness why not take a look at Deutsch Autosport connectors ;)
Post by Neosophist »
Unless i am wrong the generator is rated at 350watts and is 3 phase output.
350watts at 12v is almost 30amps! Therefore about 10amps per phase is the most it will supply, 15amp connectors or better should give you enough leeway not to melt should you decide to go connector block rout.
vfrman
Post by vfrman »
Good to know. That is what I was worried about. These connectors should be up to the task...plus they are weatherproof.
weatherproof is good, it should stop the dreaded melt from corrosion.
I replaced mine last year or the year before as it had the melt going on and was badly corroded. I only used a cheap multi block filled with dielectric grease to keep out moisture.
I think it was rated at 15amp per terminal and when I looked last week it was still fine.
