8mm Compression Tester Adaptors
Morespeedvicar
Re: 8mm Compression Tester Adaptors
Post by Morespeedvicar »
Were the ceramic insulator meets the metal its rolled over simply cut the metal were its rolled over with a saw or dremal and pull insulator out the metal bit. There not held in by much really.
If i can find me compression tester and me adapter i'll take a pic for you, but i got me KLR in hundreds of bits at the mo for engine rebuild so finding it could be a bit of a challenge!
Ian
Morespeedvicar
How to dismantle a plug...
Hope it helps.
Ian
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
Post by krisztian_andre »
It does. It's the simplest solution to the problem.
krisztian_andre
Finally I had one made:
http://postimg.org/image/qm4so7s8t/
Post by Neosophist »
krisztian_andre wrote:Finally I had one made:
Id advise putting an o-ring on the end that screws into the engine and hand tighten it only.
Like this.
Otherwise your likely to get a poor seal and inconsistent readings
