Quick action throttle
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
Post by krisztian_andre »
CRM
Admin NWAA
Admin NWAA
Re: Quick action throttle
Post by CRM »
dunno, i know the NSR250 one is a direct swop. but if you get this let me know how you get on with it pls
krisztian_andre
CRM wrote:dunno, i know the NSR250 one is a direct swop. but if you get this let me know how you get on with it pls
Will do. By the way what kind of a lubricant should I use for the throttle tube? It doesn't always return by itself.
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Post by hardnutdvd »
if it isnt returning, shouldnt that mean the cables might need adjusting rather than tubing lubricated?
Morespeedvicar
Post by Morespeedvicar »
I've always used chain lube on cables, you can get cable oilers from ebay tho I've never tried one.
krisztian_andre
Works fine (only fitted the the pull cable in the first notch), it could be a few mm-s longer. I used grease in the cable housing and chain lube on the handlebar. My handlebar was rusty and the old throttle tube was missing a piece at the end probably that's the reason it wouldn't return.
How do you install new grips? They won't go on and I don't want to use lube cause it will slip.
Last edited by krisztian_andre on Mon Sep 02, 2013 7:20 pm, edited 1 time in total.
marcus57
Post by marcus57 »
I use petrol to get new grips on hair spray
krisztian_andre
marcus57 wrote:I use petrol to get new grips on hair spray
Hairspray I don't have, doesn't petrol degrade the rubber, how about isopropyl-alcohol?
tigerclaw
Post by tigerclaw »
Unexperienced question, doesn't a quick action throttle make it more tricky to control the throttle / grip when u are riding on the edge?
krisztian_andre
tigerclaw wrote:Unexperienced question, doesn't a quick action throttle make it more tricky to control the throttle / grip when u are riding on the edge?
Probably, but then there are trade-offs to everything plus my motor only makes 49hp so there's not much of an edge.
