NC23 TRI ARM Forks
				Sc-Jon
NC23 TRI ARM Forks
howdy 400 grey guru's
my NC23 CBR400 RRJ 1988 TRI ARM failed the evil MOT , due the forks , they have small pin pricks and slightly pitted, after closer inspection they seemed to have a crease in the stanchion .
my actual question is, is there any other pair of honda forks of this era that will fit, I've seen on forums that NC29 forks might and also been told that other models may fit.. but am unsure..
any advice would be awesome
cheers Jon
cheers Jon
- Yakama
Re: NC23 TRI ARM Forks
Im pretty sure NC29 forks are too short. Check on ebay as there is loads there for sale or ask Graeme France from this forum
				stimpy
Nc29 forks are to short,if seen cbr600 units fitted
Graeme will have replacements for sure :)
				tfr125
 - Bike owned: VFR 400 NC 30, ZXR 400
Mmmm I was curious about this - so went and measured up in the garage. My 1994 NC29 forks are 722mm from the centre of the wheel spindle to the top of the stanchions - my 1989 NC23 measures 725mm. I wouldnt have thought 3mm would make a lot of difference on a road bike.
Stimpy is right, the early 600's are 41mm diameter, but are loads longer, so you would end up with about 75mm sticking out of the top yoke to keep the same ride height as standard with 400 forks.
My 2p worth
P.S if you are still after some NC23 forks I may be breaking the above 23
My 2p worth
				dunkenb
