NC29 choke RPM?
NC29 choke RPM?
Just had my carbs cleaned and rebalanced.
But I don't have choke at the Mo!
Can people post cold start on choke RPM at:
1/4th:::
1/2::::
Full out::::
I do need to replace my choke cable as fight to pull it out!
But have no change in RPM when I do get it 1/2 out....
1/4th:::
1/2::::
Full out::::
- Davez29
- Bike owned: NC29 forever
Re: NC29 choke RPM?
mines stiff as well
but it starts at around 1500 and left after a minute or so it tends to jump tween 2500 to 3000 but to be honest I normally have rode away before this due to not trying to annoy the neibours at 5:30.
Re: NC29 choke RPM?
Anyone else?
Would like to get a few replies to compare with.
Before balancing I'd get
Quqter; 3/4000 rpm
Half: 4/5000rpm
Full: can't remember as didn't use it at full
Quqter; 3/4000 rpm
Half: 4/5000rpm
Re: NC29 choke RPM?
31 views & only 1 other post...
just after a comparison.. not rocket science!
- Bike owned: GSXR1000K3 NSR125 CBR400NC29
Re: NC29 choke RPM?
Mine is just as Durkas if that's any help.
- Bike owned: NC29 CBR600F
Re: NC29 choke RPM?
Ok LP if i use any more than a whiff of choke from cold then the engine stalls so cant do full on choke or half choke rpm.leopard_pagan wrote:31 views & only 1 other post...![]()
Maybe people havent posted on this as they have an NC23 or perhaps their bike isnt running yet.
- Bike owned: CBR400RR NC29 RACEBIKE, DUCATI
Re: NC29 choke RPM?
The choke cable is meant to be stiff as it is spring return on carbs,
Where the actual knob is you can adjust the amount the oring compresses the cable if its that stiff you need Arnie to pull it out
Sorry no rpm readings mine need balancing too
Re: NC29 choke RPM?
not to the point of pulling the bike OFF side stand while trying to pull the choke out?...
almost wanna put my foot on the tank while i pull it out!
