Stainless Steel Collar dimensions
- Location: Oxford, Peterborough, new territories Hong Kong
Hi would anyone have the dimensions for Stainless steel collars for the standard system I need to make some for my standard system and a standard cut system the collars on my standard system have just rusted clean off so would know what size to make the SS ones to.
Kennon
Kennon
Re: Stainless Steel Collar dimensions
Hi, i made the ones on mine about an inch long, cant remeber the id of the pipe tho. They dont need to be an exact length aslong as the front pipes sit in nicely that'll do.
Ian
Ian
there was a near identical thread to this not long ago, I posted up pictures and measurements of my exhausts in it.KennonNC29 wrote:Hi would anyone have the dimensions for Stainless steel collars for the standard system I need to make some for my standard system and a standard cut system the collars on my standard system have just rusted clean off so would know what size to make the SS ones to.
Kennon
Do a search im sure you will find it.
I cant remember exactly off hand but if you make them 1.0mm or so smaller than stock you dont need to use the gaskets, clamps or put a compression split in it lke the orignal collars.
this is the way most aftermarket makes went for this joint (i put pics of that too.)
Just tried to look through your past posts to find it with no avail will try again in the morning.
Kennon
Kennon
If you need to know the id for the collars just measure the front pipes od.....
You need 1 1/2" tube 1.5 wall thickness i think i make them 35-38 long.
