NC24 Fork Problem
steveof
NC24 Fork Problem
Post by steveof »
Hi all, have a fork seal leaking on the right hand fork leg on my nc24.
I have taken the fork off the bike and have tried to loosen the allen bolt on the bottom of the fork but it appears that someone has had a go at it before and rounded it off.......any idea`s on how to get the bolt out..Many thanks..Steve
RICKNC31
Re: NC24 Fork Problem
Post by RICKNC31 »
Hi you could try a stud extractor socket of the correct size which may fit on the allen bolt head enough to undo it. It looks like a socket full of sliding pins best not buy but borrow if you can in case it dose not work.
steveof
Post by steveof »
problem being you can`t get a socket onto the bolt to undo it...thanks for the suggestion though
magg
Bike owned: VFR400
Post by magg »
Drill it out.
steveof
Post by steveof »
did drill it in the end,drilled half way down the bolt head and then hammered a torx bit into the remainder and out it came :grin: all I have to do now is get another bolt.....are they fairly easy to source? the threads look quite fine...
Post by Neosophist »
Yes very easy, they are a standard pitch and thread, even if it is fine itll be a common bolt.
I cant remember if the pitch is normal or fine but the part number is
90116ml0004
you can order the genuine part from david silvers for 2.56
its already been discontiniued so they dont make it anymore but there are plenty in stock if you need one.
steveof
Post by steveof »
Thanks Neo,just ordered 2,now I am going to replace the seal (and the other side is bound to start leaking)
