NC24 general questions...
Re: NC24 general questions...
I don't know but it might be that the 88/89 VFR750FJ/K[1] RC24 yokes might fit too, I wouldn't bother with the forks as they're crap but the frames are very very similar and have 41mm forks. They also come up quite often on ebay for cheap. I don't know what the steering lock is like on the NC24 but odds are it's going to be similar to the RC24 and same goes for the lock stops.
If anyone wants to give measurements the NC24 stem I can see if it's the same as the RC24 stem. I've got a spare and I'm happy to take any measurements anyone wants.
EDIT: I've just checked and the head bearings are the same between the NC21/NC24 and RC24 so it's only stem length that may change.
From http://www.patternparts.net" onclick="window.open(this.href);return false;
[1] NOT the 86/87 VFR750FG/H though as they had 37mm forks.
DruidPPT 325505 Steering Head Bearings (Lower) Honda VFR 400 NC21 & NC24 86-88 £17.45 Add
PPT 325505 Steering Head Bearings (Lower) Honda VFR 750 FG-FT 86-96 £17.45 Add
PPT 324706 Steering Head Bearings (Upper) Honda VFR 400 NC21 & NC24 86-88 £17.45 Add
PPT 324706 Steering Head Bearings (Upper) Honda VFR 750 FG-FT 86-96 £17.45 Add
Ooh intesting!! What sorta calipers came on the 750?fastdruid wrote:I don't know but it might be that the 88/89 VFR750FJ/K[1] RC24 yokes might fit too, I wouldn't bother with the forks as they're crap but the frames are very very similar and have 41mm forks. They also come up quite often on ebay for cheap. I don't know what the steering lock is like on the NC24 but odds are it's going to be similar to the RC24 and same goes for the lock stops.
From http://www.patternparts.net" onclick="window.open(this.href);return false;DruidPPT 325505 Steering Head Bearings (Lower) Honda VFR 400 NC21 & NC24 86-88 £17.45 Add
I'll check the stem length on monday / tuesday, am planning to post all the measurements up for anyone else doing stuff.
As for the original forks and air, mine have 11psi in each and hold air fine... it doesn't do much though :D
2 piston sliding Nissin calipers on the FJ/FK certainly and I believe the same on the later ones too (pads are certainly the same).Neosophist wrote:Ooh intesting!! What sorta calipers came on the 750?
But the FG-FK both have very long forks in comparison to the later VFR750's and to the NC30. Plus they have anti-dive which means the left caliper is pivoted on a funky bracket which limits the calipers you can fit without making up your own bracket.
I'm having to go with an R1 front end to my RC24 project as it's the only one any where near long enough (and still going to be too short to keep the existing geometry).
Druid
The NC24's left caliper is on exactly the same bracket, calipers also look identical. However, the NC24 has floating discs which i've on a read on a 750 forum are bolt on to that model.
No, the VFR750 has a single pad pin, those have two.
Same pads are fitted to the following
Certainly it looks like the RC24 ones should fit and as the same calipers are fitted to the VFR750 (apart from the LHS bracket) to IIRC up to 97 you could certainly get some newer ones. Do you want me to measure the essentials?
Sound's like I want NC24 discs though! What diameter are they?
Druid
The NC24's look smaller but it's hard to tell without having them side by side!CAGIVA / 900 IE "Canyon"/"Gran Canyon" (98-00)
CAGIVA / Navigator 1000 (00-03)
HONDA / CB 400 Four V/V-II/W/W-II (NC36) ±± (97-98)
HONDA / CB 400 SF (F2N/F2R/F2S/F2T/F3S) "Superfour" ±± (92-95)
HONDA / CB 750 F2N/F2R/F2S/F2T/F2V/F2W/F2X/F2Y/F21 "CB Seven Fifty" (92-02)
HONDA / CB-1 (CB 400 F) ±± (89-90)
HONDA / CBR 1000 FK/FL/FM/FN (89-92)
HONDA / CBR 250 RJ/RK/RK2 ((MC19) ±± (88-89)
HONDA / CBR 250 RRL/RRN/RRR (MC22) ±± (90-94)
HONDA / CBR 400 RRJ/RRK (NC23) "Tri -Arm" ±± (87-89)
HONDA / CBR 400 RRL/RRN/RRR (NC29) "Gull Arm" ±± (90-94)
HONDA / CBR 750 FJ "Superaero" ±± (88)
HONDA / GL 1500 CV/CW/CX (F6C) (97-99)
HONDA / GL 1500 CY/C1/C2 (F6C) (00-03)
HONDA / NTV 600 J/K/M "Revere" (88-92)
HONDA / NTV 650 J/K/L/M/P/S/T/V (88-97)
HONDA / NV 400 CS/CV "Steed" ±± (95-97)
HONDA / PC 800 "Pacific coast" (89-97)
HONDA / ST 1100 AN/AP/AR/AS "Pan European" (92-95)
HONDA / ST 1100 L/M/N/P/R/S/T/V/W/X/Y/1 "Pan European" (90-01)
HONDA / VFR 750 FJ/FK (88-89)
HONDA / VFR 750 FL/FM/FN/FP (90-93)
HONDA / VFR 750 FR/FS/FT/FV (94-97)
HONDA / VT 600 CR/CS/CT/CV/CW/CX "Shadow custom" (94-00)
HYOSUNG / Aquilia GV 125/250 (01-03)
KAWASAKI / Z 750 (ZR 750 L7F/L8F) (07-08)
KAWASAKI / Z 750 ABS (ZR 750 M7F/M8F) (07-08)
SUZUKI / AN 650 K3 Burgman (02-03)
SUZUKI / GSF 600 S/T/ST/V/SV/W/SW/X/SX "Bandit" (95-99)
SUZUKI / GSX 400 R/S/T/ZR/ZS/ZT (GK79A) "Impulse Type S" ±± (94-96)
SUZUKI / RF 400 RP/RR ±± (93-)
SUZUKI / RF 400 RP/RR/VR/RT/RVT/RV-V (GK78A) ±± (93-97)
SUZUKI / RF 600 RP/RR/RS/RT/RV (93-97)
TRIUMPH / Thruxton 900 (04-08)
VOXAN / Scrambler 1000 (02)
Druid
Give me 2 mins and i'll measure them up, popping to the shop for some beers first :)
I was worrkied about this NC30 front end too.. the forks tubes are 50mm shorted (looked on LM sprares)
-edit-
296mm floating disc
http://www.vfrdiscussion.com/forum/inde ... ntry516949" onclick="window.open(this.href);return false;
^^ Somone having them on a VFR750
-edit-
296mm floating disc
I can now tell you that a NC24 floated front brake disc fits straihgt on a 86-87 VFR750/700F Honda! I have a set mounted on my bike now! Pics lather
