[NC30] Mystery oil leak
iDemonix
Bike owned: '92 NC30
Post by iDemonix »
I unexpectedly landed a job in Abingdon which meant moving from Nottingham. Unfortunately I was half way through an engine swap, exhaust swap, swingarm swap, suspension swap, wheel paint and tyre replacement as well as a service. The bike was left at my parents and I had to nip up one weekend and rush it to make it rideable to get it down here.
Ever since, the bike pisses oil. At first I thought it was from the oil pressure valve, then I thought it was one of the bolts, then I thought the actual oil filler neck, but now I see it's pissing down from the front as well.
My only thought is that it's leaking from all around the RHS engine cover, I remember scraping the old gasket off and as I was in a rush it's possible I got it all off but didn't scrub off the some of the excess paste/muck. Going to wait until payday then order a new gasket, gasket goo and spend more money on oil which is annoying as the oil's barely 1.5k miles old.
So much to do on this bike, need to write a to-do list.
Anyone had a similar mystery leak? It only leaks when it's warm and if I take it for a blast and lay it up, there's probably half a shot glass worth of oil on the floor in the morning, maybe more, hard to tell.
Hi-Res versions:
http://i.imgur.com/QDVrHV6.jpg
http://i.imgur.com/YLCx6nx.jpg
http://i.imgur.com/emfXlCN.jpg
http://i.imgur.com/u2Mj5b2.jpg
iDemonix
Re: [NC30] Mystery oil leak
Post by iDemonix »
That last picture is on its side and was actually meant for a different thread entitled 'what's the easiest way to change the bushing in this'.
missis sumner
Bike owned: NC30 + Teapot
Post by missis sumner »
RHS oil leak? I've only had LHS, so far. Mine were rocker cover, and unconfirmed as yet, water pump. So I'm not much use to you, then, sorry... :lol:
Post by Neosophist »
no wonder its a mystery with all that oil every, thats really filthy.
get a small can of brush on gunk for a couple of quid and clean all the engine and ancillaries down.
hose it off and go for a small ride, come back and check.
oil tends to run down not up so start at the highest place.
iDemonix
Post by iDemonix »
Hi Neo,
Yeah I know, it was spotless but then my car suspension collapsed and I had no choice but to use the bike for the daily 80 mile commute so just had to let it piss oil everywhere and keep topping up.
I'll give it a clean next weekend then take it for a quick tootle round the block with no fairings on...
iDemonix
Post by iDemonix »
Just realised, I have a can of de-greaser (think there's some left) would that work? If it would then I'll go give it a clean after MotoGP.
Jac-al
Post by Jac-al »
Give it a clean then check, i had a similar problem, turned out my waterpump o-ring was gone
iDemonix
Post by iDemonix »
I cleaned it off and took it for a quick spin, it's bloody hard to identify. I think I'll drop the oil and replace the side engine casing gasket again, but this time with gasket goo as well or something.
Does anyone know where I could find the bolts for the engine casing in a better material than monkey metal? They're all different lengths etc...
bikemonkey
Post by bikemonkey »
lambchops
Post by lambchops »
I've had a mysterious leak in the RHS before and no amount of replacement gaskets could fix it. Turned out the engine cover was warped. Check to see if yours is.
