6 wire reg/rect???nc30
- V4beermonster
- Bike owned: Vfr400,gt750,vfr400/750cc
Can you fit a 6 wire reg/rec to the nc 30?? If so what do you do with the switched wire?
Re: 6 wire reg/rect???nc30
Am sure it has been done, but I'll be rogered if I know what to do with the spare wire :-)
If you can find out what the reg is off and find a wiring diagram for that bike it would be easy ish to figure out if it'd be doable or not, maybe just a case of plumbing the switched output to the ign on supply.
Ian
Ian
- speedy231278
For the sake of fart-arsing about and hoping for the best with the sixth pin, would it not be quicker and easier just to get a 5 pin reg/rec and have done with it?
- V4beermonster
Sorted black wire is a switched live from the ignition, seems to be a charge rate damper/buffer
I agree...speedy231278 wrote:For the sake of fart-arsing about and hoping for the best with the sixth pin, would it not be quicker and easier just to get a 5 pin reg/rec and have done with it?
- V4beermonster
It was just a unit I've had laying around, the one on my rebuilt bike was not charging under load, only took around an hour to fit now charging great
