New here, couple of questions!
B-Road Matt
Hi,
Got my NC30 delivered today! went for a quick blast to see how it was running, so a few questions...
-It seems that I cant get it into neutral whilst the engine is running, is this going to be a major job to fix?
-At what revs should the bike idle at?
-What tyre pressure should the tyres be at?
-How do I attach a picture to this post lol?
- starkey
Re: New here, couple of questions!
It's a common problem struggling to get the bike into neutral, you have to rev the bike up to around 3-4k revs and then put it in neutral. It should idle at around 1.3k, and both tyre pressures are 33psi.
B-Road Matt
ah ok, I shall try it thanks!
- benny
If neutral doesn't engage, just roll the bike forward slightly, (20cm) and try again, if still not then rock the bike backwards and forwards.
Had this problem on another bike but going from neutral to first, someone explained it to me, something to do with things lining up!
Mine idles between 1500 and 2k
Tyre pressure i dont know off top of my head (Haynes manual?)
To attach a picture it must be uploaded some where first ie public facebook, photobucket, flickr. then you put the images direct link in the [img] brackets that can be inserted when you are in a full post editor.
DM104 for the road race team.
- benny
Pictures postign how to thread: viewtopic.php?f=6&t=7902
B-Road Matt
I shall try that too, thanks for the tips!
Hmm mine is idling at 2 or just above but seems like its almost about to cut out, maybe I am not used to the v4?
https://www.facebook.com/photo.php?fbid ... =1&theater
Most likely its in need of a good service.B-Road Matt wrote:I shall try that too, thanks for the tips!
They should idle smooth like a fine swiss watch, even down to around 800rpm.
Most likely in need of
1. valve clearence check and set
2. carb flush and clean and check set
3. carb balance.
Time intensive (allocate a day to to the job) and youll need to buy shims and the tools if you dont have but the bike will run great afterwards.
Many young people buy the bikes as they are popular "mini racer" but dont have the time or money or knowledge to service them (A garage will charge aroudn 500 quid to do the above)
- speedy231278
I had trouble finding neutral when I first had my NC35. It started playing ball when new clutch plates were fitted. I don't know if this was a coincidence or not, mind you!
- NGneer
Just a slight 'blip' of the throttle and nutral will drop in fine - Just a bit of a quirk of these bikes.
A good service would be well worth the time and money so you know for sure the bike is properly sorted (safe) and as has been said, one done these will run so nicely. Where abouts are you located Matt? - See if there is anyone else on here nearby who may be able to lend advice/tools/helping hand
B-Road Matt
Yeah someone also told me to do the valve clearance etc but I'm no mechanic
I'm in Oxford! would be great to meet some members as am new to the area too!
