ideas for nc30 rear shock
- yayoboy
hi all, the rear shock on my nc30 functions as it should, but the powder coating on the spring has started to flake off
just wondering how easy it is to remove the spring because of the remote unit, or would it be better to just save up and plump 4 a new unit? advice plz, cheers
- Bike owned: RVF400 - ZX636
Re: ideas for nc30 rear shock
pm sent :D
- yayoboy
heres a pic of the shock, can i get the spring out without losing the gas, advice please thanks
You need to compress the spring using a set of spring compressors, you take out the collar on the bottom of the shock and can then take the spring off. The reservoir stays attached when you do this.
- yayoboy
thanks fatman, im pretty sure iv got some spring compressors in garage will try that 2moz :D
