Where's Ersan???
- bikemonkey
Re: Where's Ersan???
From the bar infront of the brake lines, infront of the headstock, inbetween the left fork and headstock, inbetween the top rad and frame to carbs.
Make sure you don't get anything tangled, like I did with my HT leads......
- speedy231278
Might not be the routing.  The freeplay on the pull cable might need adjusting.  When I put a new cable on mine, it stuck open until I added a little freeplay.  Now I've got a little too much, however the throttle no longer sticks open.
- vfrman
 - Bike owned: NC30, 1098s
Or it could be a bent bar and the tube is dragging on that.
						- Sam-NI
 - Bike owned: '89 VFR400
Again, Ersans post may have solved my problem!
							Me? The 13th Duke of Wymbourne, Here? In a French maids finishing school? At 3 O'clock in the morning?  With my reputation?
BINGEAU!
						BINGEAU!
				vic-vtrvfr
I think seeing your project is nearing an end, you should pop over the puddle & fix Ersans bike now Sam!Sam-NI wrote:Again, Ersans post may have solved my problem!
- iDemonix
 - Bike owned: '92 NC30
There'll be some drinking the night when that bike passes its MOT!
						- speedy231278
Let's just hope he doesn't have the misfortune of binning the thing after it passes.  That would be a travesty!
- xivlia
 - Bike owned: Ducati 749 D
why would i bin the thing after it passes? and, no there wont be drinking, wont be too excited either.... since the weather here is still shitty
I think speedy means he hopes you don't crash the bike.xivlia wrote:why would i bin the thing after it passes?
100+ pages later and still making peeps smile!
						- speedy231278
Cammo wrote:I think speedy means he hopes you don't crash the bike.xivlia wrote:why would i bin the thing after it passes?
I've not so much as dropped min on it's side for about 9 years now, but it's one reason I'm so paranoid about sticking new panels on. Sod's Law dictates the second I do so, something unfortunate would happen!
