NC23E in NC39 frame
BlueTec
NC23E in NC39 frame
Post by BlueTec »
Hi everybody,
I have just joined the forum.
I recently bought an SF2 Hypertec, 2002 vintage.
The engine code is NC23E, the frame code is NC39.
I am currently trying to locate a restrictor kit for the bike.
F1 International have a kit for the CB400 NC31 only.
They also appear to have a kit for NC23 (CBR400).
From a previous topic, am I correct in thinking that NC23E and NC31 are technically the same, and that the F1 kit for NC31 should be suitable for NC23E ?
Any help or suggestions welcome.
DerSchlang
Re: NC23E in NC39 frame
Post by DerSchlang »
A kit? What for?
You only need to connect 2 wires near speedometer!
BlueTec
Post by BlueTec »
Thanks for the reply.
I just logged in again today.
Could you tell me which two wires to connect?
I don't have a wiring diagram for the bike or a service manual and it would be useful to understand the electrical system layout before trying anything.
At some stage I might attempt to "reverse engineer" the electrical system, using a multimeter to map it out. I reckon it could be similar to the CB500.
superfourben
Post by superfourben »
Bit of confusion, you want to restirct the bike to 33bhp...yeah? This can only be done by putting the washers into the carbs and getting the certificate to say so... which is a restrictor kit. What der schlang is talking about is the inbuilt restricter that stops the bike doing above 180kph which is inbuilt into the bike in Japan. This can be bypassed very simply with a certain restricter across two of the wires in the clocks that I can't remember. :)
BlueTec
Post by BlueTec »
Yes, I want to restrict the engine power output to 33bhp. I don't want to bypass the inbuilt restrictor.
I understand the procedure for doing the mechanical restriction, as you have outlined...
I have spoken to F1, and alas they don't supply a kit for the NC39. http://www.400greybike.cc/newforum/post ... =32&t=3449#" onclick="window.open(this.href);return false;
:( (in case you're wondering, my bike is a HyperVtec Spec II, manufactured 2002)
I suppose I should say that when I bought the bike a few months ago I didn't check first of all to see if a restrictor kit is available. F1 can supply a kit for the NC31 (pre 1999) but not for NC39. http://www.400greybike.cc/newforum/post ... =32&t=3449#" onclick="window.open(this.href);return false;
:oops:
superfourben
As a starter, have you tried contacting worlds end motorcycles http://www.wemoto.com" onclick="window.open(this.href);return false; who may know of a different supplier for a restrictor kit, alternatively Graeme France who is a member here and is quite well known might be able to point you in the right direction.
BlueTec
Post by BlueTec »
Thanks for your help.
8-)
poshman1
Post by poshman1 »
I had the same thing when i bought my vtec spec superfour. As far as im aware there is no way of restricting this bike because of the nature of the vtec. So just rode for 6 months on an invisable restictor untill my . Insurance might be funny with you if you have a smash. Most people i know put restrictors in take them out anyway. Good luck
