NC30 clock change and no start.
Locked
xivlia
Bike owned: Ducati 749 D
Re: NC30 clock change and no start.
Post by xivlia »
yes, the green/yellow wire that is on its own? if so yes i have. it doesnt work.
xivlia
Post by xivlia »
does it matter which HT lead i wrap the rpm signal wire?
speedy231278
Post by speedy231278 »
Not unless your engine has pistons that move at different rates to one another... ;-)
xivlia
Post by xivlia »
this is so annoying.... i dont see why it cant pick up the signal.... what makes it so much more different than the stock tacho? ive tried every possible way of connecting the rpm wire... still no signal apart from the blue/white cable on the right side of the bike, while connected to that, it picks up the signal, but it shows me wrong numbers. :(
magg
Bike owned: VFR400
Post by magg »
As others have said, you do not help your cause by providing so little detail. I can only assume the blue/white wire you keep referring to is the crank pickup signal. If this in indeed the wire then it will have numerous pulses per revolution and therefore could/should cause a tacho to indicate higher rpm than actual. Also even if you can change the tacho division rate, which I am sure you can as it it a universal meter, using this signal as a pickup point may corrupt the signal such that the ignition control unit miss-performs.
Have you tried using the ignition coil primary drive signal?
xivlia
Post by xivlia »
Ignition coil primary drive signal? that is the two spade connectors at the back of the coils right? if so... no i have not tired that yet.
here is what i got from my chinese friends. these are the only instructions i got, plus the wiring numbers and its function.
magg
Bike owned: VFR400
Post by magg »
Try either the blue/ yellow or yellow/blue wires at the front or rear ignition coil. Can you post up all the info that came with the unit.
xivlia
Post by xivlia »
only other thing i got with the dash was this
i will try those wires tomorrow.
Morespeedvicar
Post by Morespeedvicar »
Guess you got it going then? lol.........
xivlia
Post by xivlia »
the bike is working yes. but the new dash wont pick up the rpm signal.
Locked
