Regulator/Rectifier location vfr400 nc24
fasttom
Bike owned: VFR 400 NC24, Kawasaki Z750
Post by fasttom »
Having a few problems locating the regulator/rectifier on my 1987 VFR400 nc24. Have looked all over the bike and cannot locate which is bizarre. The bike also seems to get power fine and charges perfectly with an Oxford charger (13.7 Volts). There doesnt seem to be any loose wires or spare connectors which also seems very odd.
Any advice would be appreciated.
thunderace
Bike owned: R6, YZF600R
Re: Regulator/Rectifier location vfr400 nc24
Post by thunderace »
It *should* be mounted under the battery box :peace:
fasttom
Post by fasttom »
mmm confusing there is nothing mounted underneath the battery holder. I have found what looks like a regulator/rec mounted under the wiring harness connector block, however I am still unsure as to if this is a reg/rec as usually in my experience they tend to have cooling fins to dissipate heat and what I have found is flat.
jetblack
Bike owned: '89 NC30 SEED
Post by jetblack »
Stock honda items are flat.
It don't matter if i'm fixin' it or ridin' it.
xivlia wrote:sorry about that whole thing jetblack, i just got confused about the whole thing, and i didnt mean any disrespect to you.
thunderace
This is a copy of the OEM one
I fitted an R6 5SL one to mine.
Post by Neosophist »
fasttom wrote:mmm confusing there is nothing mounted underneath the battery holder. I have found what looks like a regulator/rec mounted under the wiring harness connector block, however I am still unsure as to if this is a reg/rec as usually in my experience they tend to have cooling fins to dissipate heat and what I have found is flat.
Thats the fella.
Depending on the model of NC21/NC24 it will be flat or have fins. The bracket will dissipate some heat.
http://www.honda-forums.com/index.php?t ... &private=0
Here is a picture of the bracket removed and hanging down (the regulator is still attached)
fasttom
Post by fasttom »
Thanks all tracked it down it is flat as per the image which threw me off the scent. :whistle:
