Feul
DanieS
Feul
Post by DanieS »
Good day peeps.
I had my bike a NC24 for a while now and i used to use leaded (Super) petrol.
Is this correct or does the bike use Unleded? :oops:
wullvfr
Bike owned: zx9r c1
Re: Feul
Post by wullvfr »
i thought leaded fuel was no longer available....do you mean super unleaded??
it will be unleaded fuel the bike uses or should use.there is no advantage in using super unleaded unless it was very high performance etc.
:D
Re: Feul
I think DanieS is a saffa based member? No idea what the fuelling situation is over there..
The buke should run unleaded as the Japanese use it and would expect you to find no problems using unleaded fuel.
superlite
Bike owned: TLS, LB80 x 2
Re: Feul
Post by superlite »
You should be right to run unleaded as it's post '86.
'Take it to the Back'
NC35!
Re: Feul
Post by NC35! »
Hi there,
Petrol with an octane rating of 95RON or higher is ideal.
Thanks.
DanieS
Re: Feul
Post by DanieS »
I am from SA.
We have LRP ( Leaded replacement petrol ) and Unleaded
The local BP gerage and Shell gerage has 95 Unleaded but in SA the "OLD" cars use LRP and the newer cars use Unleaded.
My car uses Unleaded and if i use LRP then the car loses power and visa versa that is why i was wondering.
But if they only use Unleaded over seas then i can uses 95 Unleaded in the bike.
Re: Feul
Post by Neosophist »
yup the owners manual for the 24 states 91 or higher octane unleaded petrol
DanieS
Re: Feul
Post by DanieS »
Cool thanks guys.
I will use 95 Unleaded. ;)
