Honda 5/8" master cylinders
Re: Honda 5/8" master cylinders
on what calipers? I use mine on the CBR600FX calipers - the black larger Nissins.
I found the std 14mm was too soft and too fierce when finally it came back to the bars.
Jono
its on my cbr600 steel frame race bike, im currently using vtr firestorm fork bottoms with sp1 calipers, braided lines and my old nc35 14mm master cylinder but like you say after a while it becomes spongy and back to the bar
- thunderace
- Bike owned: R6, YZF600R
porndoguk wrote:CBR900 1992 FirebladeJono wrote:Hi does anybody know what bikes the 5/8" master cylinders came on?, i currently have a master cylinder but need a lever for it
any help will be much appreciated
cheers
Jono
VFR750 RC30
The 918cc Blade had 14mm, they only fitted 5/8" from the 929 onwards
Jono wrote:its on my cbr600 steel frame race bike, im currently using vtr firestorm fork bottoms with sp1 calipers, braided lines and my old nc35 14mm master cylinder but like you say after a while it becomes spongy and back to the bar
Aye, well get a 5/8th on it - miles better. firmer, more modulation and feels lovely. Had the same setup on my NC race bike too. Identical brake systems for road and race..they are great.
amorti
- Bike owned: CB-1, MSX125
Sorry mate it's not correct. I'm on my second 98 RRW and they both had 5/8" master from stock.thunderace wrote:porndoguk wrote:CBR900 1992 FirebladeJono wrote:Hi does anybody know what bikes the 5/8" master cylinders came on?, i currently have a master cylinder but need a lever for it
cheers
Jono
VFR750 RC30
92-97, 14mm. 98-99, 5/8". 929/954, different design and lever completely and different bore size again.
- speedy231278
Apparently a very few of the first 1992 Blades had 5/8, but they changed to 14mm very early in production, just to confuse everyone!
hunter
I have one of these it's 11/16in.
So whats the craic then,
I fitted my 5/8 and to be honest i didnt know what to expect i found that when on the 14mm MC it was sharp now im on the 5/8 i find the lever pretty weak, its blee right before anyone asks about air being in the system.
What should i expect between the two M/Cs
Rick
Rick
hunter wrote:929/954, different design and lever completely and different bore size again.
Yep, I use an 11/16 with my sp1 calipers and it's spot on.
This is the standard size used on 2003-4 600rr's also.
amorti
With the 14mm master, you will find a longer lever travel before anything happens, the brake will tend to bite very hard when you get to pad contact, you will find the lever has a softer/spongier feel.porndoguk wrote:So whats the craic then,
Rick
With the 5/8" master, you will find shorter travel, you'll need more squeeze at the lever for the same braking (this also gives more modulation and less risk of locking accidentally), the lever will feel "sharper".
It's all a matter of personal taste... the smaller master ratio was fitted as standard by eg. T595, 600SRAD, CB1300. The larger ratio on eg. '98 900RR, 750K2, ZX9R and various others. Neither choice is going to be dangerous, but more folk will complain of a spongy/vague lever on the 14 than will complain off a wooden/ on-off lever on the 5/8". I swapped to a 5/8" master on my T595 and found it much better.
If you prefer the 14m then stick with it! You've tried both now so will have an idea what you want.
